Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4653 Discussions
snmpsa-6.0-1010 ia32 is died after 30-40 secs on RHEL 5.5 OS.
akara11
I have a problem on RHEL 5.5 i686 OS. snmpsa-6.0-1010 ia32 does not work correctly but x86-64 works correctly. I tried 6.0 build14 [1] and 7.0 build14 but observed the same behavior. The snmpsa(smSubagent) process is died after 30-40 secs due to huge cpu usage.
Output of ps -ef | grep smSubagent
red color specifies process id of smSubagent
green color specified usage of cpu
root 2903 1 0 10:30 ? 00:00:00 smSubagent
root 2904 2903 77 10:30 ? 00:00:17 smSubagent
root 4942 24199 0 10:30 pts/1 00:00:00 watch -n1 ps -ef | grep smSubagent >> /tmp/pro_smSubagent.out && echo 'XXXXXXXX
root 4955 4942 0 10:30 pts/1 00:00:00 sh -c ps -ef | grep smSubagent >> /tmp/pro_smSubagent.out && echo 'XXXXXXXXXXXX
root 4957 4955 0 10:30 pts/1 00:00:00 grep smSubagent
XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
root 2904 2903 78 10:30 ? 00:00:18 smSubagent
root 4958 4942 0 10:30 pts/1 00:00:00 sh -c ps -ef | grep smSubagent >> /tmp/pro_smSubagent.out && echo 'XXXXXXXXXXXX
root 4960 4958 0 10:30 pts/1 00:00:00 grep smSubagent
root 2904 2903 79 10:30 ? 00:00:19 smSubagent
root 4964 4942 0 10:30 pts/1 00:00:00 sh -c ps -ef | grep smSubagent >> /tmp/pro_smSubagent.out && echo 'XXXXXXXXXXXX
root 4966 4964 0 10:30 pts/1 00:00:00 grep smSubagent
root 2904 2903 80 10:30 ? 00:00:21 smSubagent
root 4970 4942 0 10:30 pts/1 00:00:00 sh -c ps -ef | grep smSubagent >> /tmp/pro_smSubagent.out && echo 'XXXXXXXXXXXX
root 4972 4970 0 10:30 pts/1 00:00:00 grep smSubagent
root 2904 2903 81 10:30 ? 00:00:23 smSubagent
root 4976 4942 0 10:30 pts/1 00:00:00 sh -c ps -ef | grep smSubagent >> /tmp/pro_smSubagent.out && echo 'XXXXXXXXXXXX
root 4978 4976 0 10:30 pts/1 00:00:00 grep smSubagent
root 2904 2903 82<span lang="TR" style="fo...
David_A_Intel
Could you provide the model of the system board you are using? Additionally, please include the BIOS level it is at?
akara11
Hi David,
Thanks for your help.
Base Board Information
Manufacturer: Intel
Product Name: T5000PAL0
Version: FRU Ver 0.05
Serial Number: BZAD82300055
Asset Tag: Not Specified
Features:
Board is a hosting board
Board is replaceable
Location In Chassis: Not Specified
Chassis Handle: 0x0000
Type: Motherboard
Contained Object Handles: 0
Chassis Information
Manufacturer: TIGH2U
Type: Rack Mount Chassis
Lock: Not Present
Version: TIGH2U
Serial Number: Not Specified
Boot-up State: Safe
Power Supply State: Safe
Thermal State: Safe
Security Status: Unknown
OEM Information: 0x81581CF8
Height: 1 U
Number Of Power Cords: 1
Contained Elements: 0
SKU Number: Not Specified
BIOS Information
Vendor: Intel Corporation
Version: S5000.86B.15.00.0101.110920101604
Release Date: 11/09/2010
Address: 0xE8000
Runtime Size: 96 kB
ROM Size: 4096 kB
Characteristics:
PCI is supported
PNP is supported
BIOS is upgradeable
BIOS shadowing is allowed
Boot from CD is supported
Selectable boot is supported
EDD is supported
Print screen service is supported (int 5h)
8042 keyboard services are supported (int 9h)
Serial services are supported (int 14h)
CGA/mono video services are supported (int 10h)
ACPI is supported
USB legacy is supported
LS-120 boot is supported
ATAPI Zip drive boot is supported
BIOS boot specification is supported
Function key-initiated network boot is supported
Targeted content distribution is supported
BIOS Revision: 15.0
Firmware Revision: 0.0
David_A_Intel
I was checking the download details and I could not see this board listed. As a matter of a fact, on January 9, 2009, support for Intel(R) Carrier Grade and Industrial Servers products has been shifted from Intel to Kontron. Please contact Kontron for support on these products.
Kontron America Support Contact information:
Phone: 800-480-0044
Email: mailto:support@us.kontron.com support@us.kontron.com
Link: http://us.kontron.com/support/ http://us.kontron.com/support/
Kontron Canada Contact information:
Phone: 800-354-4223
Email: mailto:support@ca.kontron.com support@ca.kontron.com
Please find the complete list of products now supported by Kontron below:
Intel(R) IP Network Server NSC2U
Intel(R) IP Network Server NSW1U
Intel(R) IP Network Server NSI2U
Intel(R) Carrier Grade Server TIGH2U
Intel(R) Carrier Grade Server TIGW1U
Intel(R) Carrier Grade Server TIGI2U
Intel(R) Carrier Grade Server TIGPR2U
Intel(R) Carrier Grade Server TIGPT1U
Intel(R) Carrier Grade Server TSRLT2
Intel(R) Carrier Grade Server TSRMT2
