Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4806 Discussions
sr2612ur rs2bl040 raid controller and 12 drives and 2 internal drives
OSEN
I want to ask how can I connect 12 drives to rs2bl040 on a sr2612ur and also 2 drives (internal for OS ) to rs2bl040. rs2bl040 has 4 ports and I think to connect 12 drives to rs2bl040 I need 3 SFF-8087 (which has 4 ports on each SFF-8087) This will use 3 ports on rs2bl040 (which has 4 ports on raid card) and for OS (two disk) I need another SFF-8087 which makes all ports of rs2lb040 to be consumed right?
Is this the right configuration for connecting 12 sata drives + 2 internal drives and to make 2 RAID VOLUMES (one raid1 for os and one raid5 volume for all 12 drives)
Regards.
Edward_Z_Intel
Not exactly - The midplane is designed around a SAS expander. It has one SFF-8087 connector to SAS RAID adapter, providing SAS connectivity between the SAS RAID card and 12 SAS/SATA drives.
However, the RS2BL040 RAID card has only one SFF-8087 connector, meaning you have no port left for internal drives.
In your scenario, you'll need a RAID card with at least two SFF-8087 connectors. And I highly recommend you choose a RAID card from the http://www.intel.com/support/motherboards/server/s5520ur/sb/CS-030027.htm Tested hardware list. So SRCSASJV seems a good choice for you.
Another option is to connect 12 hotswap drives to the RAID controller, and two internal drives to onboard SATA ports and configure RAID 1 using ESRT2.
