Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
ss4200 amber lights auto fix
Dear,
my ss4200 after new turn on show amber light.
I am able to run web interface, but drives are not available.
when i check status of this drives it reports me, that one of the disk is new, but box was not opened. It suggest me to autocorrect this issue and the data on new disk will be lost, but after that it reports that all disks are not configured jet. Is it any way to fix this and to normally access data on the raid. Disks are WD 2TB green
Best regards
Jure
Community Manager
jure,
I am posting an Intel® Entry Storage System SS4200-E Data Recovery procedures document. I will update this thread when the document goes live on the SS4200-E support site.
Please be aware that the procedure document may not result in array, or data recovery. The recovery requires SS4200-E Linux operating system root level command line access. If you are unfamiliar with Linux command line use, Intel recommends that you not attempt to use these procedures. A command error at root level access can cause unrecoverable damage to the file system.
John
Community Manager
Here are the http://www.intel.com/support/motherboards/server/ss4200-e/sb/CS-033948.htm Intel® Entry Storage System SS4200-E array recovery procedures.
John
