Update 11/05/2013: The option to stop the Consistency check reappeared as a right-click option on the virtual drive within RAID Web Console 2. Consistency Check was stopped without incident. Considering proactive replacement of the drive.
Subject: ssr212mc2r with SRCSAS144e exhibiting strange behavior with consistency check after drive replacement
On a RAID 5 array that has been running in production for nearly 4 years, with numerous hot swap replacements of both SAS and SATA drives, on two different arrays within the 12 drive enclosure: A SATA drive failed and went off line. The drive was marked offline with the Intel Raid Web Console (LSI), a new drive was inserted, and the rebuild commenced and completed. A subsequent consistency check has continued to "iterate", with the error messages seeming to indicate a potential issue with the new drive.
My question is: Is there a problem marking the suspected bad drive offline with a subsequent replace and rebuild while the "background initialization" from the consistency check is occurring?
Below are the most interesting log entries:
ID = 113
SEQUENCE NUMBER = 823175
TIME = 04-11-2013 10:53:11
LOCALIZED MESSAGE = Controller ID: 0 Unexpected sense: PD = Ports 4-7:1:3 - Invalid field in CDB, CDB = 0x4d 0x00 0x4d 0x00 0x00 0x00 0x00 0x00 0x20 0x00 , Sense = 0x70 0x00 0x05 0x00 0x00 0x00 0x00 0x0a 0x00 0x00 0x00 0x00 0x24 0x00 0x00 0x00 0x00 0x00
ID = 113
SEQUENCE NUMBER = 823173
TIME = 04-11-2013 10:53:03
LOCALIZED MESSAGE = Controller ID: 0 Unexpected sense: PD = Ports 4-7:1:6 - Invalid field in CDB, CDB = 0x4d 0x00 0x4d 0x00 0x00 0x00 0x00 0x00 0x20 0x00 , Sense = 0x70 0x00 0x05 0x00 0x00 0x00 0x00 0x0a 0x00 0x00 0x00 0x00 0x24 0x00 0x00 0x00 0x00 0x00
ID = 113
SEQUENCE NUMBER = 823170
TIME = 04-11-2013 10:51:18
LOCALIZED MESSAGE = Controller ID: 0 Unexpected sense: PD = Ports 4-7:1:11 - Invalid field in CDB, CDB = 0x4d 0x00 0x4d 0x00 0x00 0x00 0x00 0x00 0x20 0x00 , Sense = 0x70 0x00 0x05 0x00 0x00 0x00 0x00 0x0a 0x00 0x00 0x00 0x00 0x24 0x00 0x00 0x00 0x00 0x00
ID = 113
SEQUENCE NUMBER = 823169
TIME = 04-11-2013 10:51:08
LOCALIZED MESSAGE = Controller ID: 0 Unexpected sense: PD = Ports 4-7:1:10 - Invalid field in CDB, CDB = 0x4d 0x00 0x4d 0x00 0x00 0x00 0x00 0x00 0x20 0x00 , Sense = 0x70 0x00 0x05 0x00 0x00 0x00 0x00 0x0a 0x00 0x00 0x00 0x00 0x24 0x00 0x00 0x00 0x00 0x00
ID = 113
SEQUENCE NUMBER = 823167
TIME = 04-11-2013 10:50:09
LOCALIZED MESSAGE = Controller ID: 0 Unexpected sense: PD = Ports 4-7:1:2 - Invalid field in CDB, CDB = 0x4d 0x00 0x4d 0x00 0x00 0x00 0x00 0x00 0x20 0x00 , Sense = 0x70 0x00 0x05 0x00 0x00 0x00 0x00 0x0a 0x00 0x00 0x00 0x00 0x24 0x00 0x00 0x00 0x00 0x00
ID = 63
SEQUENCE NUMBER = 823154
TIME = 04-11-2013 10:41:13
LOCALIZED MESSAGE = Controller ID: 0 Consistency Check found inconsistent parity on VD strip: ( VD = 1, strip = 0xe35a2)
ID = 63
SEQUENCE NUMBER = 823147
TIME = 04-11-2013 10:35:58
LOCALIZED MESSAGE = Controller ID: 0 Consistency Check found inconsistent parity on VD strip: ( VD = 1, strip = 0xb4b0d)
ID = 63
SEQUENCE NUMBER = 823143
TIME = 04-11-2013 10:33:59
LOCALIZED MESSAGE = Controller ID: 0 Consistency Check found inconsistent parity on VD strip: ( VD = 1, strip = 0xa2cc6)
ID = 63
SEQUENCE NUMBER = 823138
TIME = 04-11-2013 10:30:46
LOCALIZED MESSAGE = Controller ID: 0 Consistency Check found inconsistent parity on VD strip: ( VD = 1, strip = 0x8629c)
ID = 60
SEQUENCE NUMBER = 823118
TIME = 04-11-2013 10:16:00
LOCALIZED MESSAGE = Controller ID: 0 Consistency Check detected uncorrectable multiple medium errors: ( PD Ports 4-7:1:10 Location 0x26f222 VD 1)
ID = 66
SEQUENCE NUMBER = 823116
TIME = 04-11-2013 10:15:28
LOCALIZED MESSAGE = Controller ID: 0 Consistency Check started on VD: 1
