running window vista internet explorer 9 since i have upgraded to internet explorer 9 , now when i want to update my network wireless driver through the intel driver update utility it doesnt show me the result and it causes the internet explorer to stop working which states that a problem caused the program to stop working correctly... i never had this problem with IE 8 any solution as to why and what could be done
thank you
allure
- Tags:
- Drivers
Looks like a bug in the IDUU code - see http://communities.intel.com/thread/20883?start=15&tstart=0 http://communities.intel.com/thread/20883?start=15&tstart=0
I Had The Same Problem Which I Solved By Going To Tools>Internet Options>Advanced>Accelerated Graphics & Put A Check In The Use Software Rendering Instead Of GPU Rendering* Box. (I Have A Nvidia Video Card (GPU) And It's Works Perfect With Or Without The Box Checked Onboard Intel Video I Have To Check The Box When Checking For Intel Updates) Hope This Helps Good Luck!!
thank you Al... it worked , been waiting for a solution thank you again.
just a follow up... after i have ran the intel driver update utility it found a newer version update for my wireless networking , so i went ahead and updated it then i ran again the update driver utility after a restart , it found the same new version that i have updated already? any idea as to what it means? usually when you do the update it should not come again ?
thank you
allure
