Server Products
4784 Discussions
what are the minimum encrypted required ports to work KVM redirection using stunnel
User1585051830145643
I have board S2600WTTR (BIOS ate latest 028) and KVM redirection set to Stunnel encrption and encrypted ports are open in firewall are 7582, 5124, and 5127
still getting error : "Some Global2" and "KVMCLIENT".Also RESET coming from the IPMI
we want to allow only encrpyted port for Remote console to work In addition to the standard TCP/IP ports for browsing the Web interface (80 and 443)
SergioS_Intel
Hello User15850518301456433508,
Can you please provide us how are you creating the encryption and when you are getting the error messages?
Sergio S.
For firmware updates and troubleshooting tips, visit :https://intel.com/support/serverbios
Selecting Stunnel from configuration KVM & Media and Launch Remote Console using jnlp and black console opened up with error as per attachment
Dont want to keep open any un-encrypted port for this(Remote console ) operation
SergioS_Intel
Thank you for the additional information, please allow us some time to check on your question.
Sergio S.
SergioS_Intel
First, we would like to apologize for the delay on our response.
The secure ports that you are using are correct. When KVM encryption is enabled, KVM protocol uses port 7582 for KVM, 5124 for CD/DVD, 5127 for floppy/USB.
Another requirement for KVM encryption is that firewall (if any) and NAT should be configured to permit these connections. Besides that, there are no other requirements.
Can you please a screenshot of any error messages you could be getting?
Sergio S.
Thanks no issue , allowing only encrypted ports at firewall does not open remote console using IPMI. PFA error . what are the other required ports other than 7582 for KVM, 5124 for CD/DVD, 5127 are necessary to kept open , remote console to work ? or should it work with mentioned ports only ?
SergioS_Intel
Thank you for sharing the screenshot of the error, please allow us more time to investigate.
SergioS_Intel
You have already opened all the necessary ports. The indicated ports are the only ones that can be used:
KVM related ports (7582, 5124, 5127), http 80 and TCP 443.
This is covered in section 9.3.2 of TPS.
We also would like to know what is the browser you are using. The validated ones are Microsoft Internet Explorer and Mozilla Firefox.
Does KVM work fine when encryption is set to "none"?
In a past interaction, the customer stated: "Also RESET coming from the IPMI". Can you please let us know what you meant by that?
We will be looking forward to your answer.
Sergio S.
Used Mozilla Firefox.
Reg: Does KVM work fine when encryption is set to "none"?
Yes
SergioS_Intel
We appreciate the additional information, one last question can you please also let us know what did you mean with "RESET coming from the IPMI".
Thank you
Sergio S.
SergioS_Intel
We are following your case and we would like to know if you found the information from the previous post that we sent you.
Thank you
Sergio S.
Yes , confirmed from your previous communication that (KVM related ports (7582, 5124, 5127), http 80 and TCP 443) these are the only ports should be open and remote console should work , but unfortunately in our case its not working
Request coming on port 7582 is allow as action on firewall but showing session end reason "tcp-rst-from-server"
SergioS_Intel
Thank you for the information we are going to check on the information provided and will get back to you.
Sergio S.
Emeth_O_Intel
We would like to ask you the following details in order to have a better understanding of this scenario:
  • Which browser is used to access BMC web console?
  • Does KVM work fine if encryption is set to "none"?
  • Extract Debug logs and sysinfo logs from the system.
Please let us know the outcome in order to proceed with the next step.
Emeth O.
Intel Server Specialist.
Which browser is used to access BMC web console? = Firefox
Does KVM work fine if encryption is set to "none"? = yes
will try to collect logs
Emeth_O_Intel
Thank you for replying back.
Please share with us the logs as soon as possible in order to proceed with the next step.
If you have more questions, do not hesitate and let me know and I will be more than happy to assist you.
Emeth O.
Emeth_O_Intel
I have been following up on your case in order to verify if you still have questions?
Emeth O.
Hi, due to current situation not able to get logs , need to wait , sorry for delay from my side .
SergioS_Intel
Thank you for taking the time to share that information with us. We are going to keep this thread open and will follow up with you next week.
Sergio S.
SergioS_Intel
This message is to let you know that we are still waiting for the logs and we do understand that you are still not able to get them.
We will follow up with you in two weeks.
Sergio S.
SergioS_Intel
I am following your case and we would like to let you know if you were able to get the logs requested on the previous post.
Sergio S.
