Server Products
All support for Intel NUC 7 - 13 systems has transitioned to ASUS. Read latest update.
4724 Discussions
what does correctable ecc asserted explicily mean?
BGuo2
I have "correctable ecc asserted" warning in the bmc of my server. This event probably lead to the server status light turned amber and blink. I wonder is this event mean only one bit error occurred in the dimm or the number of error occurred in that dimm exceeded the threshold? If it is the first case, I think it is ok, and won't lead to any server health problem. I hope someone can help me with this!
Hello Mr. Guo,
In regards to your question the BMC error messages could change from board to board and even with the firmware version. Could you please specify what board/chassis model you have on your server and what BIOS version is it currently running?
Jose H.
BGuo2
board:s2600cw2r
BIOS01010022
ME030103043
BMC015010802
FRUSDR114
thank you for your help!
Hello Mr. Guo,
Thanks for the info.
Are you seen this error message from the Server Health > DIMM Information tab? I couldn't find the exact description of the error even on the BMC user guide: http://download.intel.com/support/motherboards/server/sb/intel_rmm4_ibwc_userguide_r2_72.pdf http://download.intel.com/support/motherboards/server/sb/intel_rmm4_ibwc_userguide_r2_72.pdf
I will continue researching on this and will get back to you with updates
Jose H.
BGuo2
No. I saw this in the even log.
Sorry for this late reply, but I was on a business trip last week.
Mr. Guo,
Do you mind to share that event log file here? I would like to take a look at it.
Jose H.
Hello Mr. Guo,
Let me share with you the following info in regards to Correctable Error Correcting Code (ECC) or other correctable memory error for memory modules
  1. Decode DIMM error(s) using the https://www.intel.com/content/www/us/en/support/server-products/000023940.html System Information Retrieval Utility.
  2. Verify the DIMM is seated properly.
  3. Examine gold fingers on edge of the DIMM to ensure that the contacts are clean.
  4. Inspect the processor socket DIMM for any bent contacts/pins. If you find bent contacts/pins, replace the board.
  5. Consider replacing the DIMM as a preventive measure if the correctable error becomes uncorrectable.
Hope this helps.
Jose H.
Hello Mr. Guo,
Do you have updates in regards to this?
Just let me know.
Jose H.
Hello Mr. Guo,
I will proceed to mark this thread as closed. If you have further questions just create a new topic and we will be glad to assist you.
Jose H.
