Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage; and Intel® Xeon® Processors
The Intel sign-in experience is changing in February to support enhanced security controls. If you sign in, click here for more information.
4481 Discussions
yellow bangs on Win Srvr 2008 R2 server core after installing PRO/1000 PT
I get yellow bangs in remote Device Manager after attempting to install a PRO/1000 PT NIC in a Dell PowerEdge 2900 III
, BIOS rev 2.6.1 up to date. The OS is Windows Server 2008 R2 datacenter server core, and is a hyper-v host. It has 2 Broadcom nextxreme II 5704c onboard NICs.
To start, I downloaded the latest driver PROWinx64.exe dated 4/29/10, version 15.2 and ran the install on the local console. It appeared to complete fine. Then I saw the yellow bangs on the NICs in remote DM. Sure enough, Windows didn't recognize the devices, and i was unable to assign them to virtual networks in hyper-v. Here's a dump of everything I can think of. Thanks in advance for any suggestions you have on solving this problem.
Running adaptchk.exe
Intel(R) PRO/1000 PT Dual Port Server Adapter # 2:
Cannot find a supported driver for this adapter. Make sure that the latest Intel® Network Connections PCI Express driver is installed. For the latest drivers and a complete list of networking adapters supported by this utility please see support.intel.com.
BIOS reports the PT NIC has IRQ 5 and 6 assigned.
PROSetCL.exe can identify all 4 NICs
C:\Program Files\Intel\DMIX\CL>PROSetCL.exe ADAPTer_enumerate
Number of adapters currently present: 4
1) Intel(R) PRO/1000 PT Dual Port Server Adapter # 2
2) Broadcom BCM5708C NetXtreme II GigE (NDIS VBD Client)
3) Broadcom BCM5708C NetXtreme II GigE (NDIS VBD Client) # 2
4) Intel(R) PRO/1000 PT Dual Port Server Adapter
C:\Program Files\Intel\DMIX\CL>PROSetCL.exe ADAPTer_enumeratesettings 4
Settings:
*FlowControl - Rx & Tx Enabled
*InterruptModeration - Enabled
*IPChecksumOffloadIPv4 - Rx & Tx Enabled
*JumboPacket - Disabled
*LsoV2IPv4 - Enabled
*LsoV2IPv6 - Enabled
*PriorityVLANTag - Priority & VLAN Enabled
*RSS - Enabled
*SpeedDuplex - Auto Negotiation
*TCPChecksumOffloadIPv4 - Rx & Tx Enabled
*TCPChecksumOffloadIPv6 - Rx & Tx Enabled
*UDPChecksumOffloadIPv4 - Rx & Tx Enabled
*UDPChecksumOffloadIPv6 - Rx & Tx Enabled
AdaptiveIFS - Disabled
ITR - Adaptive
LogLinkStateEvent - Enabled
MasterSlave - Auto Detect
SPDEnabled - Hardware Default
WaitAutoNegComplete - Auto Detect
*ReceiveBuffers - 256
*TransmitBuffers - 512
NetworkAddress -
ConnectionName - Local Area Connection 7
C:\Program Files\Intel\DMIX\CL>PROSetCL.exe ADAPTer_enumeratesettings 1
Settings:
NetworkAddress -
ConnectionName - Local Area Connection 8
*RSS - Enabled
EnablePME - Disabled
ITR - Adaptive
WakeOn - OS Controlled
WakeOnLink - Disabled
PNPUTIL shows the following drivers loaded.
C:\Users\jano>pnputil -e
Microsoft PnP Utility
Published name : oem0.inf
Driver package provider : Intel
Class : Network adapters
Driver date and version : 10/01/2009 9.0.13.0
Signer name : Microsoft Windows Hardware Compatibility Publisher
Published name : oem1.inf
Driver date and version : 03/26/2010 9.13.41.0
Published name : oem2.inf
Driver date and version : 04/12/2010 11.6.92.0
Published name : oem3.inf
Driver date and version : 12/04/2009 11.4.7.0
Published name : oem4.inf
Driver date and version : 01/07/2010 11.4.16.0
Published name : oem5.inf
Driver date and version : 04/07/2010 10.1.9.0
Published name : oem6.inf
Driver date and version : 12/01/2009 2.4.28.0
Published name : ...
Mark_H_Intel
I never tried running the executable in a core only installation, but I suspect that the install is not completing properly on a core only installation.
You should extract the files from the webpack and perform a command line installation using DxSetup.exe.
Check http://downloadmirror.intel.com/18725/eng/readme.htm the Read Me for information on how to extract the files and then run a command line installation.
Let us know if using the command line install solves the problem.
Mark H
thanks for the quick reply Mark. i'll give it a shot. but first, should I force delete the installed driver packages (pnputil -f -d) that windows reports in use (one for each of the PT ports)? or can i just apply the install from the commandline, and it will overwrite?
Mark_H_Intel
I do not have specific knowledge for your situation. Usually, you can just run the install and everything works. I would try the install first and only try the other command if you have trouble with the install.
I wish I knew a tried and true procedure for this situation. I am curious to hear what works for you.
No joy.
installing from the command line had the effect of installing two new driver packages that pnputil shows as oem2.inf and oem3.inf. the original drivers oem0 and oem1 are still there, presumably the drivers from the first install. i ended up doing a force delete on all the drivers with pnputil -f -d, and reinstalling again, but to no avail.
there were some other configuration issues I wasn't happy with so I'm going to flatten the server, reinstall the OS, and then install the drivers before trying adding the hyper-v role and re-attaching the VMs.
Before i flattened the machine, I thought I would give the driver install one more try.
This time, adapter 1 was recognized and shows up fine in DM, but adapter 2 is not. this is a head scratcher.
