Software Archive
Read-only legacy content
64bit build error
Gary_C_
I'm seeing a build error when building on my ubuntu linux x86 box to generate yocto full image. Anyone else see this error? Works fine on a 32bit build machine.  It takes to long to build on my 32bit build machine. My 64bit machine should only take less than an hour or so to build.  32cores.
git repo: git://git.yoctoproject.org/meta-intel-iot-devkit
ERROR: Task 238 (virtual:native:/export/yocto-intel/meta-intel-iot-devkit/meta/recipes-devtools/syslinux/syslinux_6.01.bb, do_install) failed with exit code '1'
DEBUG: Executing shell function do_install
NOTE: make -j 32 BINDIR=/export/yocto-intel/meta-intel-iot-devkit/build/tmp/sysroots/x86_64-linux/usr/bin SBINDIR=/export/yocto-intel/meta-intel-iot-devkit/build/tmp/sysroots/x86_64-linux/usr/sbin LIBDIR=/export/yocto-intel/meta-intel-iot-devkit/build/tmp/sysroots/x86_64-linux/usr/lib DATADIR=/export/yocto-intel/meta-intel-iot-devkit/build/tmp/sysroots/x86_64-linux/usr/share MANDIR=/export/yocto-intel/meta-intel-iot-devkit/build/tmp/sysroots/x86_64-linux/usr/share/man INCDIR=/export/yocto-intel/meta-intel-iot-devkit/build/tmp/sysroots/x86_64-linux/usr/include CC=gcc  -isystem/export/yocto-intel/meta-intel-iot-devkit/build/tmp/sysroots/x86_64-linux/usr/include -O2 -pipe install INSTALLROOT=/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/image firmware=bios
make -r -C /export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01 -f /export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/Makefile SRC="/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01" \
        OBJ=/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01 objdir=/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01 install
make[1]: Entering directory `/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01'
make -r -r -C /export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/bios -f /export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/Makefile SRC="/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01" \
        objdir=/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/bios OBJ=/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/bios HAVE_FIRMWARE=1 \
        ARCH=i386 LDLINUX=ldlinux.c32 install
make[2]: Entering directory `/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/bios'
set -e; for i in libinstaller mtools linux extlinux utils; \
        do make -r -r -r -C $i SRC="/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/$i" OBJ="/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/bios/$i" \
        -f /export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/$i/Makefile all; done
make[3]: Entering directory `/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/bios/libinstaller'
make[3]: Nothing to be done for `all'.
make[3]: Leaving directory `/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/bios/libinstaller'
make[3]: Entering directory `/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/bios/mtools'
make[3]: Leaving directory `/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/bios/mtools'
make[3]: Entering directory `/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/bios/linux'
make[3]: Leaving directory `/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/bios/linux'
make[3]: Entering directory `/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/bios/extlinux'
make[3]: Leaving directory `/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/bios/extlinux'
make[3]: Entering directory `/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/bios/utils'
make[3]: Leaving directory `/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/bios/utils'
mkdir -m 755 -p /export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/image/export/yocto-intel/meta-intel-iot-devkit/build/tmp/sysroots/x86_64-linux/usr/bin
install -m 755 -c mtools/syslinux /export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/image/export/yocto-intel/meta-intel-iot-devkit/build/tmp/sysroots/x86_64-linux/usr/bin
mkdir -m 755 -p /export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/image/export/yocto-intel/meta-intel-iot-devkit/build/tmp/sysroots/x86_64-linux/usr/sbin
install -m 755 -c extlinux/extlinux /export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/image/export/yocto-intel/meta-intel-iot-devkit/build/tmp/sysroots/x86_64-linux/usr/sbin
mkdir -m 755 -p /export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/image/export/yocto-intel/meta-intel-iot-devkit/build/tmp/sysroots/x86_64-linux/usr/share/syslinux
install -m 644 -c core/pxelinux.0 gpxe/gpxelinux.0 gpxe/gpxelinuxk.0 core/isolinux.bin core/isolinux-debug.bin dos/syslinux.com core/lpxelinux.0 mbr/*.bin memdisk/memdisk memdump/memdump.com com32/menu/*.c32 com32/modules/*.c32 com32/mboot/*.c32 com32/hdt/*.c32 com32/rosh/*.c32 com32/gfxboot/*.c32 com32/sysdump/*.c32 com32/lua/src/*.c32 com32/chain/*.c32 com32/lib/*.c32 com32/libutil/*.c32 com32/gpllib/*.c32 com32/elflink/ldlinux/*.c32 com32/cmenu/libmenu/*.c32 /export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/image/export/yocto-intel/meta-intel-iot-devkit/build/tmp/sysroots/x86_64-linux/usr/share/syslinux
install -m 644 -c win64/syslinux64.exe /export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/image/export/yocto-intel/meta-intel-iot-devkit/build/tmp/sysroots/x86_64-linux/usr/share/syslinux
mkdir -m 755 -p /export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/image/export/yocto-intel/meta-intel-iot-devkit/build/tmp/sysroots/x86_64-linux/usr/share/syslinux/diag
install -m 644 -c diag/mbr/handoff.bin diag/geodsp/geodsp1s.img.xz diag/geodsp/geodspms.img.xz /export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/image/export/yocto-intel/meta-intel-iot-devkit/build/tmp/sysroots/x86_64-linux/usr/share/syslinux/diag
mkdir -m 755 -p /export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/image/export/yocto-intel/meta-intel-iot-devkit/build/tmp/sysroots/x86_64-linux/usr/share/man/man1
install -m 644 -c /export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/man/*.1 /export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/image/export/yocto-intel/meta-intel-iot-devkit/build/tmp/sysroots/x86_64-linux/usr/share/man/man1
: mkdir -m 755 -p /export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/image/export/yocto-intel/meta-intel-iot-devkit/build/tmp/sysroots/x86_64-linux/usr/share/man/man8
: install -m 644 -c man/*.8 /export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/image/export/yocto-intel/meta-intel-iot-devkit/build/tmp/sysroots/x86_64-linux/usr/share/man/man8
set -e ; for i in com32 utils dosutil ; \
        -f /export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/$i/Makefile install; done
make[3]: Entering directory `/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/bios/com32'
make -r -r -r -C /export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/bios/com32/libupload SRC="/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32"/libupload OBJ="/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/bios/com32"/libupload/ \
        -f /export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/libupload/Makefile install
make -r -r -r -C /export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/bios/com32/tools SRC="/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32"/tools OBJ="/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/bios/com32"/tools/ \
        -f /export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/tools/Makefile install
make -r -r -r -C /export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/bios/com32/lib SRC="/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32"/lib OBJ="/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/bios/com32"/lib/ \
        -f /export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/lib/Makefile install
make -r -r -r -C /export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/bios/com32/gpllib SRC="/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32"/gpllib OBJ="/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/bios/com32"/gpllib/ \
        -f /export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/gpllib/Makefile install
make -r -r -r -C /export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/bios/com32/libutil SRC="/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32"/libutil OBJ="/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/bios/com32"/libutil/ \
        -f /export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/libutil/Makefile install
make -r -r -r -C /export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/bios/com32/elflink SRC="/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32"/elflink OBJ="/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/bios/com32"/elflink/ \
        -f /export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/elflink/Makefile install
make[4]: Entering directory `/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/bios/com32/tools'
make[4]: Nothing to be done for `install'.
make[4]: Leaving directory `/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/bios/com32/tools'
make[4]: Entering directory `/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/bios/com32/elflink'
make[4]: Leaving directory `/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/bios/com32/elflink'
make[4]: Entering directory `/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/bios/com32/libutil'
ld -m elf_i386 -shared --hash-style=gnu -T /export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/lib/i386/elf.ld --as-needed -soname libutil.c32 -o libutil.elf ansiline.o ansiraw.o keyname.o sha1hash.o unbase64.o md5.o crypt-md5.o sha256crypt.o sha512crypt.o base64.o quicksort.o
rm -f libutil_lnx.a
ar cq libutil_lnx.a ansiline.lo ansiraw.lo keyname.lo sha1hash.lo unbase64.lo md5.lo crypt-md5.lo sha256crypt.lo sha512crypt.lo base64.lo quicksort.lo
ld: i386:x86-64 architecture of input file `ansiline.o' is incompatible with i386 output
ld: i386:x86-64 architecture of input file `ansiraw.o' is incompatible with i386 output
ld: i386:x86-64 architecture of input file `keyname.o' is incompatible with i386 output
ld: i386:x86-64 architecture of input file `sha1hash.o' is incompatible with i386 output
ld: i386:x86-64 architecture of input file `unbase64.o' is incompatible with i386 output
ld: i386:x86-64 architecture of input file `md5.o' is incompatible with i386 output
ld: i386:x86-64 architecture of input file `crypt-md5.o' is incompatible with i386 output
ld: i386:x86-64 architecture of input file `sha256crypt.o' is incompatible with i386 output
ld: i386:x86-64 architecture of input file `sha512crypt.o' is incompatible with i386 output
ld: i386:x86-64 architecture of input file `base64.o' is incompatible with i386 output
ld: i386:x86-64 architecture of input file `quicksort.o' is incompatible with i386 output
ansiline.o: In function `console_ansi_std':
ansiline.c:(.text+0x3): undefined reference to `dev_ansiserial_w'
ansiline.c:(.text+0xa): undefined reference to `dev_stdcon_r'
ansiline.c:(.text+0xf): undefined reference to `openconsole'
ansiraw.o: In function `console_ansi_raw':
ansiraw.c:(.text+0x3): undefined reference to `dev_ansiserial_w'
ansiraw.c:(.text+0xa): undefined reference to `dev_rawcon_r'
ansiraw.c:(.text+0xf): undefined reference to `openconsole'
keyname.o: In function `key_name_to_code':
keyname.c:(.text+0x40): undefined reference to `strcasecmp'
crypt-md5.o: In function `crypt_md5':
crypt-md5.c:(.text+0x5f): undefined reference to `strncmp'
sha256crypt.o: In function `sha256_crypt_r':
sha256crypt.c:(.text+0x4af): undefined reference to `strncmp'
sha256crypt.c:(.text+0x4cd): undefined reference to `strncmp'
sha256crypt.c:(.text+0x4e2): undefined reference to `strtoul'
sha256crypt.c:(.text+0x544): undefined reference to `strcspn'
sha256crypt.c:(.text+0x965): undefined reference to `stpncpy'
sha256crypt.c:(.text+0x9a7): undefined reference to `snprintf'
sha256crypt.c:(.text+0x9e3): undefined reference to `stpncpy'
sha256crypt.c:(.text+0xd12): undefined reference to `errno'
sha256crypt.o: In function `sha256_crypt':
sha256crypt.c:(.text+0xdcd): undefined reference to `realloc'
sha512crypt.o: In function `sha512_crypt_r':
sha512crypt.c:(.text+0x586): undefined reference to `strncmp'
sha512crypt.c:(.text+0x5a4): undefined reference to `strncmp'
sha512crypt.c:(.text+0x5b9): undefined reference to `strtoul'
sha512crypt.c:(.text+0x61b): undefined reference to `strcspn'
sha512crypt.c:(.text+0xa34): undefined reference to `stpncpy'
sha512crypt.c:(.text+0xa6f): undefined reference to `snprintf'
sha512crypt.c:(.text+0xaa4): undefined reference to `stpncpy'
sha512crypt.c:(.text+0x10df): undefined reference to `errno'
sha512crypt.o: In function `sha512_crypt':
sha512crypt.c:(.text+0x11a2): undefined reference to `realloc'
quicksort.o: In function `quick_sort_range':
quicksort.c:(.text+0x1e): undefined reference to `lrand48'
make[4]: *** [libutil.elf] Error 1
make[4]: *** Waiting for unfinished jobs....
ranlib libutil_lnx.a
make[4]: Leaving directory `/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/bios/com32/libutil'
make[3]: *** [libutil] Error 2
make[3]: *** Waiting for unfinished jobs....
make[4]: Entering directory `/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/bios/com32/lib'
make[4]: Entering directory `/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/bios/com32/gpllib'
gcc  -isystem/export/yocto-intel/meta-intel-iot-devkit/build/tmp/sysroots/x86_64-linux/usr/include -O2 -pipe -Wp,-MT,zlib/adler32.o,-MD,zlib/.adler32.o.d -Os -march=i386 -falign-functions=0 -falign-jumps=0 -falign-labels=0 -ffast-math -fomit-frame-pointer -std=gnu99   -fno-stack-protector -fwrapv -freg-struct-return -fPIC -fno-exceptions -fno-asynchronous-unwind-tables -fno-strict-aliasing -falign-functions=0 -falign-jumps=0 -falign-labels=0 -falign-loops=0 -g -D__COM32__ -nostdinc -iwithprefix include -I. -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/lib/sys -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/lib/../include -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/include/sys -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/core/include -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/lib/ -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/lib/sys/module -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/bios/com32/lib//../.. -W -Wall -Wstrict-prototypes  -Wpointer-arith -Wwrite-strings -Wstrict-prototypes -Winline -DDYNAMIC_CRC_TABLE -DPNG_NO_CONSOLE_IO -DPNG_NO_WRITE_SUPPORTED -DPNG_NO_MNG_FEATURES -DPNG_NO_READ_tIME -DPNG_NO_WRITE_tIME -mregparm=3 -DREGPARM=3 -c -o zlib/adler32.o /export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/lib/zlib/adler32.c
gcc  -isystem/export/yocto-intel/meta-intel-iot-devkit/build/tmp/sysroots/x86_64-linux/usr/include -O2 -pipe -Wp,-MT,cpuid.o,-MD,./.cpuid.o.d -Os -march=i386 -falign-functions=0 -falign-jumps=0 -falign-labels=0 -ffast-math -fomit-frame-pointer -std=gnu99   -fno-stack-protector -fwrapv -freg-struct-return -fPIC -fno-exceptions -fno-asynchronous-unwind-tables -fno-strict-aliasing -falign-functions=0 -falign-jumps=0 -falign-labels=0 -falign-loops=0 -g -D__COM32__ -nostdinc -iwithprefix include -I. -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/gpllib/sys -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/gpllib/../include -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/include/sys -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/core/include -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/lib/ -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/lib/sys/module -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/bios/com32/gpllib//../.. -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/gpllib/../gplinclude -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/gpllib/../gplinclude/zzjson -W -Wall -Wstrict-prototypes  -Wpointer-arith -Wwrite-strings -Wstrict-prototypes -Winline -DDYNAMIC_CRC_TABLE -DPNG_NO_CONSOLE_IO -DPNG_NO_WRITE_SUPPORTED -DPNG_NO_MNG_FEATURES -DPNG_NO_READ_tIME -DPNG_NO_WRITE_tIME -mregparm=3 -DREGPARM=3 -c -o cpuid.o /export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/gpllib/cpuid.c
gcc  -isystem/export/yocto-intel/meta-intel-iot-devkit/build/tmp/sysroots/x86_64-linux/usr/include -O2 -pipe -Wp,-MT,zlib/compress.o,-MD,zlib/.compress.o.d -Os -march=i386 -falign-functions=0 -falign-jumps=0 -falign-labels=0 -ffast-math -fomit-frame-pointer -std=gnu99   -fno-stack-protector -fwrapv -freg-struct-return -fPIC -fno-exceptions -fno-asynchronous-unwind-tables -fno-strict-aliasing -falign-functions=0 -falign-jumps=0 -falign-labels=0 -falign-loops=0 -g -D__COM32__ -nostdinc -iwithprefix include -I. -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/lib/sys -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/lib/../include -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/include/sys -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/core/include -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/lib/ -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/lib/sys/module -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/bios/com32/lib//../.. -W -Wall -Wstrict-prototypes  -Wpointer-arith -Wwrite-strings -Wstrict-prototypes -Winline -DDYNAMIC_CRC_TABLE -DPNG_NO_CONSOLE_IO -DPNG_NO_WRITE_SUPPORTED -DPNG_NO_MNG_FEATURES -DPNG_NO_READ_tIME -DPNG_NO_WRITE_tIME -mregparm=3 -DREGPARM=3 -c -o zlib/compress.o /export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/lib/zlib/compress.c
make[4]: Entering directory `/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/bios/com32/libupload'
mkdir -m 755 -p /export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/image/export/yocto-intel/meta-intel-iot-devkit/build/tmp/sysroots/x86_64-linux/usr/share/syslinux/com32
gcc  -isystem/export/yocto-intel/meta-intel-iot-devkit/build/tmp/sysroots/x86_64-linux/usr/include -O2 -pipe -Wp,-MT,memory.o,-MD,./.memory.o.d -Os -march=i386 -falign-functions=0 -falign-jumps=0 -falign-labels=0 -ffast-math -fomit-frame-pointer -std=gnu99   -fno-stack-protector -fwrapv -freg-struct-return -fPIC -fno-exceptions -fno-asynchronous-unwind-tables -fno-strict-aliasing -falign-functions=0 -falign-jumps=0 -falign-labels=0 -falign-loops=0 -g -D__COM32__ -nostdinc -iwithprefix include -I. -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/gpllib/sys -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/gpllib/../include -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/include/sys -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/core/include -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/lib/ -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/lib/sys/module -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/bios/com32/gpllib//../.. -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/gpllib/../gplinclude -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/gpllib/../gplinclude/zzjson -W -Wall -Wstrict-prototypes  -Wpointer-arith -Wwrite-strings -Wstrict-prototypes -Winline -DDYNAMIC_CRC_TABLE -DPNG_NO_CONSOLE_IO -DPNG_NO_WRITE_SUPPORTED -DPNG_NO_MNG_FEATURES -DPNG_NO_READ_tIME -DPNG_NO_WRITE_tIME -mregparm=3 -DREGPARM=3 -c -o memory.o /export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/gpllib/memory.c
gcc  -isystem/export/yocto-intel/meta-intel-iot-devkit/build/tmp/sysroots/x86_64-linux/usr/include -O2 -pipe -Wp,-MT,zlib/crc32.o,-MD,zlib/.crc32.o.d -Os -march=i386 -falign-functions=0 -falign-jumps=0 -falign-labels=0 -ffast-math -fomit-frame-pointer -std=gnu99   -fno-stack-protector -fwrapv -freg-struct-return -fPIC -fno-exceptions -fno-asynchronous-unwind-tables -fno-strict-aliasing -falign-functions=0 -falign-jumps=0 -falign-labels=0 -falign-loops=0 -g -D__COM32__ -nostdinc -iwithprefix include -I. -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/lib/sys -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/lib/../include -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/include/sys -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/core/include -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/lib/ -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/lib/sys/module -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/bios/com32/lib//../.. -W -Wall -Wstrict-prototypes  -Wpointer-arith -Wwrite-strings -Wstrict-prototypes -Winline -DDYNAMIC_CRC_TABLE -DPNG_NO_CONSOLE_IO -DPNG_NO_WRITE_SUPPORTED -DPNG_NO_MNG_FEATURES -DPNG_NO_READ_tIME -DPNG_NO_WRITE_tIME -mregparm=3 -DREGPARM=3 -c -o zlib/crc32.o /export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/lib/zlib/crc32.c
gcc  -isystem/export/yocto-intel/meta-intel-iot-devkit/build/tmp/sysroots/x86_64-linux/usr/include -O2 -pipe -Wp,-MT,disk/ata.o,-MD,disk/.ata.o.d -Os -march=i386 -falign-functions=0 -falign-jumps=0 -falign-labels=0 -ffast-math -fomit-frame-pointer -std=gnu99   -fno-stack-protector -fwrapv -freg-struct-return -fPIC -fno-exceptions -fno-asynchronous-unwind-tables -fno-strict-aliasing -falign-functions=0 -falign-jumps=0 -falign-labels=0 -falign-loops=0 -g -D__COM32__ -nostdinc -iwithprefix include -I. -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/gpllib/sys -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/gpllib/../include -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/include/sys -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/core/include -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/lib/ -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/lib/sys/module -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/bios/com32/gpllib//../.. -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/gpllib/../gplinclude -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/gpllib/../gplinclude/zzjson -W -Wall -Wstrict-prototypes  -Wpointer-arith -Wwrite-strings -Wstrict-prototypes -Winline -DDYNAMIC_CRC_TABLE -DPNG_NO_CONSOLE_IO -DPNG_NO_WRITE_SUPPORTED -DPNG_NO_MNG_FEATURES -DPNG_NO_READ_tIME -DPNG_NO_WRITE_tIME -mregparm=3 -DREGPARM=3 -c -o disk/ata.o /export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/gpllib/disk/ata.c
install -m 644 libcom32upload.a /export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/image/export/yocto-intel/meta-intel-iot-devkit/build/tmp/sysroots/x86_64-linux/usr/share/syslinux/com32
gcc  -isystem/export/yocto-intel/meta-intel-iot-devkit/build/tmp/sysroots/x86_64-linux/usr/include -O2 -pipe -Wp,-MT,disk/bootloaders.o,-MD,disk/.bootloaders.o.d -Os -march=i386 -falign-functions=0 -falign-jumps=0 -falign-labels=0 -ffast-math -fomit-frame-pointer -std=gnu99   -fno-stack-protector -fwrapv -freg-struct-return -fPIC -fno-exceptions -fno-asynchronous-unwind-tables -fno-strict-aliasing -falign-functions=0 -falign-jumps=0 -falign-labels=0 -falign-loops=0 -g -D__COM32__ -nostdinc -iwithprefix include -I. -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/gpllib/sys -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/gpllib/../include -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/include/sys -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/core/include -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/lib/ -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/lib/sys/module -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/bios/com32/gpllib//../.. -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/gpllib/../gplinclude -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/gpllib/../gplinclude/zzjson -W -Wall -Wstrict-prototypes  -Wpointer-arith -Wwrite-strings -Wstrict-prototypes -Winline -DDYNAMIC_CRC_TABLE -DPNG_NO_CONSOLE_IO -DPNG_NO_WRITE_SUPPORTED -DPNG_NO_MNG_FEATURES -DPNG_NO_READ_tIME -DPNG_NO_WRITE_tIME -mregparm=3 -DREGPARM=3 -c -o disk/bootloaders.o /export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/gpllib/disk/bootloaders.c
gcc  -isystem/export/yocto-intel/meta-intel-iot-devkit/build/tmp/sysroots/x86_64-linux/usr/include -O2 -pipe -Wp,-MT,zlib/uncompr.o,-MD,zlib/.uncompr.o.d -Os -march=i386 -falign-functions=0 -falign-jumps=0 -falign-labels=0 -ffast-math -fomit-frame-pointer -std=gnu99   -fno-stack-protector -fwrapv -freg-struct-return -fPIC -fno-exceptions -fno-asynchronous-unwind-tables -fno-strict-aliasing -falign-functions=0 -falign-jumps=0 -falign-labels=0 -falign-loops=0 -g -D__COM32__ -nostdinc -iwithprefix include -I. -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/lib/sys -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/lib/../include -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/include/sys -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/core/include -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/lib/ -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/lib/sys/module -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/bios/com32/lib//../.. -W -Wall -Wstrict-prototypes  -Wpointer-arith -Wwrite-strings -Wstrict-prototypes -Winline -DDYNAMIC_CRC_TABLE -DPNG_NO_CONSOLE_IO -DPNG_NO_WRITE_SUPPORTED -DPNG_NO_MNG_FEATURES -DPNG_NO_READ_tIME -DPNG_NO_WRITE_tIME -mregparm=3 -DREGPARM=3 -c -o zlib/uncompr.o /export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/lib/zlib/uncompr.c
gcc  -isystem/export/yocto-intel/meta-intel-iot-devkit/build/tmp/sysroots/x86_64-linux/usr/include -O2 -pipe -Wp,-MT,disk/errno_disk.o,-MD,disk/.errno_disk.o.d -Os -march=i386 -falign-functions=0 -falign-jumps=0 -falign-labels=0 -ffast-math -fomit-frame-pointer -std=gnu99   -fno-stack-protector -fwrapv -freg-struct-return -fPIC -fno-exceptions -fno-asynchronous-unwind-tables -fno-strict-aliasing -falign-functions=0 -falign-jumps=0 -falign-labels=0 -falign-loops=0 -g -D__COM32__ -nostdinc -iwithprefix include -I. -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/gpllib/sys -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/gpllib/../include -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/include/sys -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/core/include -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/lib/ -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/lib/sys/module -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/bios/com32/gpllib//../.. -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/gpllib/../gplinclude -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/gpllib/../gplinclude/zzjson -W -Wall -Wstrict-prototypes  -Wpointer-arith -Wwrite-strings -Wstrict-prototypes -Winline -DDYNAMIC_CRC_TABLE -DPNG_NO_CONSOLE_IO -DPNG_NO_WRITE_SUPPORTED -DPNG_NO_MNG_FEATURES -DPNG_NO_READ_tIME -DPNG_NO_WRITE_tIME -mregparm=3 -DREGPARM=3 -c -o disk/errno_disk.o /export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/gpllib/disk/errno_disk.c
gcc  -isystem/export/yocto-intel/meta-intel-iot-devkit/build/tmp/sysroots/x86_64-linux/usr/include -O2 -pipe -Wp,-MT,zlib/deflate.o,-MD,zlib/.deflate.o.d -Os -march=i386 -falign-functions=0 -falign-jumps=0 -falign-labels=0 -ffast-math -fomit-frame-pointer -std=gnu99   -fno-stack-protector -fwrapv -freg-struct-return -fPIC -fno-exceptions -fno-asynchronous-unwind-tables -fno-strict-aliasing -falign-functions=0 -falign-jumps=0 -falign-labels=0 -falign-loops=0 -g -D__COM32__ -nostdinc -iwithprefix include -I. -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/lib/sys -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/lib/../include -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/include/sys -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/core/include -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/lib/ -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/lib/sys/module -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/bios/com32/lib//../.. -W -Wall -Wstrict-prototypes  -Wpointer-arith -Wwrite-strings -Wstrict-prototypes -Winline -DDYNAMIC_CRC_TABLE -DPNG_NO_CONSOLE_IO -DPNG_NO_WRITE_SUPPORTED -DPNG_NO_MNG_FEATURES -DPNG_NO_READ_tIME -DPNG_NO_WRITE_tIME -mregparm=3 -DREGPARM=3 -c -o zlib/deflate.o /export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/lib/zlib/deflate.c
mkdir -p /export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/image/export/yocto-intel/meta-intel-iot-devkit/build/tmp/sysroots/x86_64-linux/usr/share/syslinux/com32/include/
gcc  -isystem/export/yocto-intel/meta-intel-iot-devkit/build/tmp/sysroots/x86_64-linux/usr/include -O2 -pipe -Wp,-MT,disk/error.o,-MD,disk/.error.o.d -Os -march=i386 -falign-functions=0 -falign-jumps=0 -falign-labels=0 -ffast-math -fomit-frame-pointer -std=gnu99   -fno-stack-protector -fwrapv -freg-struct-return -fPIC -fno-exceptions -fno-asynchronous-unwind-tables -fno-strict-aliasing -falign-functions=0 -falign-jumps=0 -falign-labels=0 -falign-loops=0 -g -D__COM32__ -nostdinc -iwithprefix include -I. -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/gpllib/sys -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/gpllib/../include -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/include/sys -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/core/include -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/lib/ -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/lib/sys/module -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/bios/com32/gpllib//../.. -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/gpllib/../gplinclude -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/gpllib/../gplinclude/zzjson -W -Wall -Wstrict-prototypes  -Wpointer-arith -Wwrite-strings -Wstrict-prototypes -Winline -DDYNAMIC_CRC_TABLE -DPNG_NO_CONSOLE_IO -DPNG_NO_WRITE_SUPPORTED -DPNG_NO_MNG_FEATURES -DPNG_NO_READ_tIME -DPNG_NO_WRITE_tIME -mregparm=3 -DREGPARM=3 -c -o disk/error.o /export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/gpllib/disk/error.c
gcc  -isystem/export/yocto-intel/meta-intel-iot-devkit/build/tmp/sysroots/x86_64-linux/usr/include -O2 -pipe -Wp,-MT,disk/geom.o,-MD,disk/.geom.o.d -Os -march=i386 -falign-functions=0 -falign-jumps=0 -falign-labels=0 -ffast-math -fomit-frame-pointer -std=gnu99   -fno-stack-protector -fwrapv -freg-struct-return -fPIC -fno-exceptions -fno-asynchronous-unwind-tables -fno-strict-aliasing -falign-functions=0 -falign-jumps=0 -falign-labels=0 -falign-loops=0 -g -D__COM32__ -nostdinc -iwithprefix include -I. -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/gpllib/sys -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/gpllib/../include -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/include/sys -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/core/include -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/lib/ -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/lib/sys/module -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/bios/com32/gpllib//../.. -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/gpllib/../gplinclude -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/gpllib/../gplinclude/zzjson -W -Wall -Wstrict-prototypes  -Wpointer-arith -Wwrite-strings -Wstrict-prototypes -Winline -DDYNAMIC_CRC_TABLE -DPNG_NO_CONSOLE_IO -DPNG_NO_WRITE_SUPPORTED -DPNG_NO_MNG_FEATURES -DPNG_NO_READ_tIME -DPNG_NO_WRITE_tIME -mregparm=3 -DREGPARM=3 -c -o disk/geom.o /export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/gpllib/disk/geom.c
cp -r /export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/libupload/*.h /export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/image/export/yocto-intel/meta-intel-iot-devkit/build/tmp/sysroots/x86_64-linux/usr/share/syslinux/com32/include/
/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/lib/zlib/adler32.c:1:0: error: CPU you selected does not support x86-64 instruction set
 /* adler32.c -- compute the Adler-32 checksum of a data stream
/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/lib/zlib/compress.c:1:0: error: CPU you selected does not support x86-64 instruction set
 /* compress.c -- compress a memory buffer
gcc  -isystem/export/yocto-intel/meta-intel-iot-devkit/build/tmp/sysroots/x86_64-linux/usr/include -O2 -pipe -Wp,-MT,zlib/trees.o,-MD,zlib/.trees.o.d -Os -march=i386 -falign-functions=0 -falign-jumps=0 -falign-labels=0 -ffast-math -fomit-frame-pointer -std=gnu99   -fno-stack-protector -fwrapv -freg-struct-return -fPIC -fno-exceptions -fno-asynchronous-unwind-tables -fno-strict-aliasing -falign-functions=0 -falign-jumps=0 -falign-labels=0 -falign-loops=0 -g -D__COM32__ -nostdinc -iwithprefix include -I. -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/lib/sys -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/lib/../include -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/include/sys -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/core/include -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/lib/ -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/lib/sys/module -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/bios/com32/lib//../.. -W -Wall -Wstrict-prototypes  -Wpointer-arith -Wwrite-strings -Wstrict-prototypes -Winline -DDYNAMIC_CRC_TABLE -DPNG_NO_CONSOLE_IO -DPNG_NO_WRITE_SUPPORTED -DPNG_NO_MNG_FEATURES -DPNG_NO_READ_tIME -DPNG_NO_WRITE_tIME -mregparm=3 -DREGPARM=3 -c -o zlib/trees.o /export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/lib/zlib/trees.c
/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/lib/zlib/compress.c:1:0: warning: -mregparm is ignored in 64-bit mode [enabled by default]
/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/lib/zlib/adler32.c:1:0: warning: -mregparm is ignored in 64-bit mode [enabled by default]
gcc  -isystem/export/yocto-intel/meta-intel-iot-devkit/build/tmp/sysroots/x86_64-linux/usr/include -O2 -pipe -Wp,-MT,disk/labels.o,-MD,disk/.labels.o.d -Os -march=i386 -falign-functions=0 -falign-jumps=0 -falign-labels=0 -ffast-math -fomit-frame-pointer -std=gnu99   -fno-stack-protector -fwrapv -freg-struct-return -fPIC -fno-exceptions -fno-asynchronous-unwind-tables -fno-strict-aliasing -falign-functions=0 -falign-jumps=0 -falign-labels=0 -falign-loops=0 -g -D__COM32__ -nostdinc -iwithprefix include -I. -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/gpllib/sys -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/gpllib/../include -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/include/sys -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/core/include -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/lib/ -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/lib/sys/module -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/bios/com32/gpllib//../.. -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/gpllib/../gplinclude -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/gpllib/../gplinclude/zzjson -W -Wall -Wstrict-prototypes  -Wpointer-arith -Wwrite-strings -Wstrict-prototypes -Winline -DDYNAMIC_CRC_TABLE -DPNG_NO_CONSOLE_IO -DPNG_NO_WRITE_SUPPORTED -DPNG_NO_MNG_FEATURES -DPNG_NO_READ_tIME -DPNG_NO_WRITE_tIME -mregparm=3 -DREGPARM=3 -c -o disk/labels.o /export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/gpllib/disk/labels.c
gcc  -isystem/export/yocto-intel/meta-intel-iot-devkit/build/tmp/sysroots/x86_64-linux/usr/include -O2 -pipe -Wp,-MT,zlib/zutil.o,-MD,zlib/.zutil.o.d -Os -march=i386 -falign-functions=0 -falign-jumps=0 -falign-labels=0 -ffast-math -fomit-frame-pointer -std=gnu99   -fno-stack-protector -fwrapv -freg-struct-return -fPIC -fno-exceptions -fno-asynchronous-unwind-tables -fno-strict-aliasing -falign-functions=0 -falign-jumps=0 -falign-labels=0 -falign-loops=0 -g -D__COM32__ -nostdinc -iwithprefix include -I. -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/lib/sys -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/lib/../include -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/include/sys -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/core/include -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/lib/ -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/lib/sys/module -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/bios/com32/lib//../.. -W -Wall -Wstrict-prototypes  -Wpointer-arith -Wwrite-strings -Wstrict-prototypes -Winline -DDYNAMIC_CRC_TABLE -DPNG_NO_CONSOLE_IO -DPNG_NO_WRITE_SUPPORTED -DPNG_NO_MNG_FEATURES -DPNG_NO_READ_tIME -DPNG_NO_WRITE_tIME -mregparm=3 -DREGPARM=3 -c -o zlib/zutil.o /export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/lib/zlib/zutil.c
/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/gpllib/cpuid.c:1:0: error: CPU you selected does not support x86-64 instruction set
/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/gpllib/cpuid.c:1:0: warning: -mregparm is ignored in 64-bit mode [enabled by default]
/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/gpllib/memory.c:1:0: error: CPU you selected does not support x86-64 instruction set
/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/gpllib/memory.c:1:0: warning: -mregparm is ignored in 64-bit mode [enabled by default]
gcc  -isystem/export/yocto-intel/meta-intel-iot-devkit/build/tmp/sysroots/x86_64-linux/usr/include -O2 -pipe -Wp,-MT,disk/mbrs.o,-MD,disk/.mbrs.o.d -Os -march=i386 -falign-functions=0 -falign-jumps=0 -falign-labels=0 -ffast-math -fomit-frame-pointer -std=gnu99   -fno-stack-protector -fwrapv -freg-struct-return -fPIC -fno-exceptions -fno-asynchronous-unwind-tables -fno-strict-aliasing -falign-functions=0 -falign-jumps=0 -falign-labels=0 -falign-loops=0 -g -D__COM32__ -nostdinc -iwithprefix include -I. -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/gpllib/sys -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/gpllib/../include -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/include/sys -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/core/include -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/lib/ -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/lib/sys/module -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/bios/com32/gpllib//../.. -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/gpllib/../gplinclude -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/gpllib/../gplinclude/zzjson -W -Wall -Wstrict-prototypes  -Wpointer-arith -Wwrite-strings -Wstrict-prototypes -Winline -DDYNAMIC_CRC_TABLE -DPNG_NO_CONSOLE_IO -DPNG_NO_WRITE_SUPPORTED -DPNG_NO_MNG_FEATURES -DPNG_NO_READ_tIME -DPNG_NO_WRITE_tIME -mregparm=3 -DREGPARM=3 -c -o disk/mbrs.o /export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/gpllib/disk/mbrs.c
gcc  -isystem/export/yocto-intel/meta-intel-iot-devkit/build/tmp/sysroots/x86_64-linux/usr/include -O2 -pipe -Wp,-MT,disk/msdos.o,-MD,disk/.msdos.o.d -Os -march=i386 -falign-functions=0 -falign-jumps=0 -falign-labels=0 -ffast-math -fomit-frame-pointer -std=gnu99   -fno-stack-protector -fwrapv -freg-struct-return -fPIC -fno-exceptions -fno-asynchronous-unwind-tables -fno-strict-aliasing -falign-functions=0 -falign-jumps=0 -falign-labels=0 -falign-loops=0 -g -D__COM32__ -nostdinc -iwithprefix include -I. -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/gpllib/sys -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/gpllib/../include -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/include/sys -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/core/include -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/lib/ -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/lib/sys/module -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/bios/com32/gpllib//../.. -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/gpllib/../gplinclude -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/gpllib/../gplinclude/zzjson -W -Wall -Wstrict-prototypes  -Wpointer-arith -Wwrite-strings -Wstrict-prototypes -Winline -DDYNAMIC_CRC_TABLE -DPNG_NO_CONSOLE_IO -DPNG_NO_WRITE_SUPPORTED -DPNG_NO_MNG_FEATURES -DPNG_NO_READ_tIME -DPNG_NO_WRITE_tIME -mregparm=3 -DREGPARM=3 -c -o disk/msdos.o /export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/gpllib/disk/msdos.c
gcc  -isystem/export/yocto-intel/meta-intel-iot-devkit/build/tmp/sysroots/x86_64-linux/usr/include -O2 -pipe -Wp,-MT,zlib/inflate.o,-MD,zlib/.inflate.o.d -Os -march=i386 -falign-functions=0 -falign-jumps=0 -falign-labels=0 -ffast-math -fomit-frame-pointer -std=gnu99   -fno-stack-protector -fwrapv -freg-struct-return -fPIC -fno-exceptions -fno-asynchronous-unwind-tables -fno-strict-aliasing -falign-functions=0 -falign-jumps=0 -falign-labels=0 -falign-loops=0 -g -D__COM32__ -nostdinc -iwithprefix include -I. -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/lib/sys -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/lib/../include -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/include/sys -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/core/include -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/lib/ -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/lib/sys/module -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/bios/com32/lib//../.. -W -Wall -Wstrict-prototypes  -Wpointer-arith -Wwrite-strings -Wstrict-prototypes -Winline -DDYNAMIC_CRC_TABLE -DPNG_NO_CONSOLE_IO -DPNG_NO_WRITE_SUPPORTED -DPNG_NO_MNG_FEATURES -DPNG_NO_READ_tIME -DPNG_NO_WRITE_tIME -mregparm=3 -DREGPARM=3 -c -o zlib/inflate.o /export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/lib/zlib/inflate.c
gcc  -isystem/export/yocto-intel/meta-intel-iot-devkit/build/tmp/sysroots/x86_64-linux/usr/include -O2 -pipe -Wp,-MT,disk/read.o,-MD,disk/.read.o.d -Os -march=i386 -falign-functions=0 -falign-jumps=0 -falign-labels=0 -ffast-math -fomit-frame-pointer -std=gnu99   -fno-stack-protector -fwrapv -freg-struct-return -fPIC -fno-exceptions -fno-asynchronous-unwind-tables -fno-strict-aliasing -falign-functions=0 -falign-jumps=0 -falign-labels=0 -falign-loops=0 -g -D__COM32__ -nostdinc -iwithprefix include -I. -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/gpllib/sys -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/gpllib/../include -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/include/sys -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/core/include -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/lib/ -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/lib/sys/module -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/bios/com32/gpllib//../.. -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/gpllib/../gplinclude -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/gpllib/../gplinclude/zzjson -W -Wall -Wstrict-prototypes  -Wpointer-arith -Wwrite-strings -Wstrict-prototypes -Winline -DDYNAMIC_CRC_TABLE -DPNG_NO_CONSOLE_IO -DPNG_NO_WRITE_SUPPORTED -DPNG_NO_MNG_FEATURES -DPNG_NO_READ_tIME -DPNG_NO_WRITE_tIME -mregparm=3 -DREGPARM=3 -c -o disk/read.o /export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/gpllib/disk/read.c
/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/gpllib/disk/errno_disk.c:1:0: error: CPU you selected does not support x86-64 instruction set
/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/gpllib/disk/errno_disk.c:1:0: warning: -mregparm is ignored in 64-bit mode [enabled by default]
/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/gpllib/disk/ata.c:1:0: error: CPU you selected does not support x86-64 instruction set
 #include <inttypes.h>
/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/gpllib/disk/ata.c:1:0: warning: -mregparm is ignored in 64-bit mode [enabled by default]
/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/lib/zlib/crc32.c:1:0: error: CPU you selected does not support x86-64 instruction set
 /* crc32.c -- compute the CRC-32 of a data stream
/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/lib/zlib/crc32.c:1:0: warning: -mregparm is ignored in 64-bit mode [enabled by default]
/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/gpllib/disk/error.c:1:0: error: CPU you selected does not support x86-64 instruction set
/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/gpllib/disk/error.c:1:0: warning: -mregparm is ignored in 64-bit mode [enabled by default]
gcc  -isystem/export/yocto-intel/meta-intel-iot-devkit/build/tmp/sysroots/x86_64-linux/usr/include -O2 -pipe -Wp,-MT,disk/swsusp.o,-MD,disk/.swsusp.o.d -Os -march=i386 -falign-functions=0 -falign-jumps=0 -falign-labels=0 -ffast-math -fomit-frame-pointer -std=gnu99   -fno-stack-protector -fwrapv -freg-struct-return -fPIC -fno-exceptions -fno-asynchronous-unwind-tables -fno-strict-aliasing -falign-functions=0 -falign-jumps=0 -falign-labels=0 -falign-loops=0 -g -D__COM32__ -nostdinc -iwithprefix include -I. -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/gpllib/sys -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/gpllib/../include -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/include/sys -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/core/include -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/lib/ -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/lib/sys/module -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/bios/com32/gpllib//../.. -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/gpllib/../gplinclude -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/gpllib/../gplinclude/zzjson -W -Wall -Wstrict-prototypes  -Wpointer-arith -Wwrite-strings -Wstrict-prototypes -Winline -DDYNAMIC_CRC_TABLE -DPNG_NO_CONSOLE_IO -DPNG_NO_WRITE_SUPPORTED -DPNG_NO_MNG_FEATURES -DPNG_NO_READ_tIME -DPNG_NO_WRITE_tIME -mregparm=3 -DREGPARM=3 -c -o disk/swsusp.o /export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/gpllib/disk/swsusp.c
/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/gpllib/disk/bootloaders.c:1:0: error: CPU you selected does not support x86-64 instruction set
/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/gpllib/disk/bootloaders.c:1:0: warning: -mregparm is ignored in 64-bit mode [enabled by default]
gcc  -isystem/export/yocto-intel/meta-intel-iot-devkit/build/tmp/sysroots/x86_64-linux/usr/include -O2 -pipe -Wp,-MT,zlib/infback.o,-MD,zlib/.infback.o.d -Os -march=i386 -falign-functions=0 -falign-jumps=0 -falign-labels=0 -ffast-math -fomit-frame-pointer -std=gnu99   -fno-stack-protector -fwrapv -freg-struct-return -fPIC -fno-exceptions -fno-asynchronous-unwind-tables -fno-strict-aliasing -falign-functions=0 -falign-jumps=0 -falign-labels=0 -falign-loops=0 -g -D__COM32__ -nostdinc -iwithprefix include -I. -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/lib/sys -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/lib/../include -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/include/sys -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/core/include -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/lib/ -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/lib/sys/module -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/bios/com32/lib//../.. -W -Wall -Wstrict-prototypes  -Wpointer-arith -Wwrite-strings -Wstrict-prototypes -Winline -DDYNAMIC_CRC_TABLE -DPNG_NO_CONSOLE_IO -DPNG_NO_WRITE_SUPPORTED -DPNG_NO_MNG_FEATURES -DPNG_NO_READ_tIME -DPNG_NO_WRITE_tIME -mregparm=3 -DREGPARM=3 -c -o zlib/infback.o /export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/lib/zlib/infback.c
/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/lib/zlib/deflate.c:1:0: error: CPU you selected does not support x86-64 instruction set
 /* deflate.c -- compress data using the deflation algorithm
/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/lib/zlib/deflate.c:1:0: warning: -mregparm is ignored in 64-bit mode [enabled by default]
gcc  -isystem/export/yocto-intel/meta-intel-iot-devkit/build/tmp/sysroots/x86_64-linux/usr/include -O2 -pipe -Wp,-MT,zlib/inftrees.o,-MD,zlib/.inftrees.o.d -Os -march=i386 -falign-functions=0 -falign-jumps=0 -falign-labels=0 -ffast-math -fomit-frame-pointer -std=gnu99   -fno-stack-protector -fwrapv -freg-struct-return -fPIC -fno-exceptions -fno-asynchronous-unwind-tables -fno-strict-aliasing -falign-functions=0 -falign-jumps=0 -falign-labels=0 -falign-loops=0 -g -D__COM32__ -nostdinc -iwithprefix include -I. -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/lib/sys -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/lib/../include -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/include/sys -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/core/include -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/lib/ -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/lib/sys/module -I/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/bios/com32/lib//../.. -W -Wall -Wstrict-prototypes  -Wpointer-arith -Wwrite-strings -Wstrict-prototypes -Winline -DDYNAMIC_CRC_TABLE -DPNG_NO_CONSOLE_IO -DPNG_NO_WRITE_SUPPORTED -DPNG_NO_MNG_FEATURES -DPNG_NO_READ_tIME -DPNG_NO_WRITE_tIME -mregparm=3 -DREGPARM=3 -c -o zlib/inftrees.o /export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/lib/zlib/inftrees.c
/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/lib/zlib/uncompr.c:1:0: error: CPU you selected does not support x86-64 instruction set
 /* uncompr.c -- decompress a memory buffer
/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/lib/zlib/uncompr.c:1:0: warning: -mregparm is ignored in 64-bit mode [enabled by default]
make[4]: Leaving directory `/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/bios/com32/libupload'
make[4]: *** [memory.o] Error 1
/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/lib/zlib/trees.c:1:0: error: CPU you selected does not support x86-64 instruction set
 /* trees.c -- output deflated data using Huffman coding
/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/lib/zlib/trees.c:1:0: warning: -mregparm is ignored in 64-bit mode [enabled by default]
/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/gpllib/disk/geom.c:1:0: error: CPU you selected does not support x86-64 instruction set
/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/gpllib/disk/geom.c:1:0: warning: -mregparm is ignored in 64-bit mode [enabled by default]
/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/gpllib/disk/mbrs.c:1:0: error: CPU you selected does not support x86-64 instruction set
/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/gpllib/disk/mbrs.c:1:0: warning: -mregparm is ignored in 64-bit mode [enabled by default]
/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/lib/zlib/zutil.c:1:0: error: CPU you selected does not support x86-64 instruction set
 /* zutil.c -- target dependent utility functions for the compression library
/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/lib/zlib/zutil.c:1:0: warning: -mregparm is ignored in 64-bit mode [enabled by default]
/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/gpllib/disk/labels.c:1:0: error: CPU you selected does not support x86-64 instruction set
/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/gpllib/disk/labels.c:1:0: warning: -mregparm is ignored in 64-bit mode [enabled by default]
make[4]: *** [zlib/adler32.o] Error 1
make[4]: *** [zlib/compress.o] Error 1
make[4]: *** [disk/errno_disk.o] Error 1
make[4]: *** [disk/ata.o] Error 1
make[4]: *** [cpuid.o] Error 1
/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/gpllib/disk/msdos.c:1:0: error: CPU you selected does not support x86-64 instruction set
/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/gpllib/disk/msdos.c:1:0: warning: -mregparm is ignored in 64-bit mode [enabled by default]
/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/gpllib/disk/read.c:1:0: error: CPU you selected does not support x86-64 instruction set
/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/gpllib/disk/read.c:1:0: warning: -mregparm is ignored in 64-bit mode [enabled by default]
/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/lib/zlib/inflate.c:1:0: error: CPU you selected does not support x86-64 instruction set
 /* inflate.c -- zlib decompression
make[4]: *** [zlib/uncompr.o] Error 1
/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/lib/zlib/inflate.c:1:0: warning: -mregparm is ignored in 64-bit mode [enabled by default]
make[4]: *** [disk/error.o] Error 1
make[4]: *** [disk/bootloaders.o] Error 1
make[4]: *** [zlib/crc32.o] Error 1
/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/lib/zlib/infback.c:1:0: error: CPU you selected does not support x86-64 instruction set
 /* infback.c -- inflate using a call-back interface
/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/lib/zlib/infback.c:1:0: warning: -mregparm is ignored in 64-bit mode [enabled by default]
/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/gpllib/disk/swsusp.c:1:0: error: CPU you selected does not support x86-64 instruction set
 #include <stdlib.h>
/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/gpllib/disk/swsusp.c:1:0: warning: -mregparm is ignored in 64-bit mode [enabled by default]
/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/lib/zlib/inftrees.c:1:0: error: CPU you selected does not support x86-64 instruction set
 /* inftrees.c -- generate Huffman trees for efficient decoding
/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/com32/lib/zlib/inftrees.c:1:0: warning: -mregparm is ignored in 64-bit mode [enabled by default]
make[4]: *** [disk/mbrs.o] Error 1
make[4]: *** [zlib/zutil.o] Error 1
make[4]: *** [zlib/deflate.o] Error 1
make[4]: *** [disk/geom.o] Error 1
make[4]: *** [zlib/trees.o] Error 1
make[4]: *** [zlib/inflate.o] Error 1
make[4]: *** [disk/msdos.o] Error 1
make[4]: *** [disk/labels.o] Error 1
make[4]: *** [disk/swsusp.o] Error 1
make[4]: *** [zlib/infback.o] Error 1
make[4]: *** [disk/read.o] Error 1
make[4]: Leaving directory `/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/bios/com32/gpllib'
make[3]: *** [gpllib] Error 2
make[4]: *** [zlib/inftrees.o] Error 1
make[4]: Leaving directory `/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/bios/com32/lib'
make[3]: *** [lib] Error 2
make[3]: Leaving directory `/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/bios/com32'
make[2]: *** [install] Error 2
make[2]: Leaving directory `/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01/bios'
make[1]: *** [bios] Error 2
make[1]: Leaving directory `/export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/syslinux-6.01'
make: *** [install] Error 2
ERROR: oe_runmake failed
WARNING: exit code 1 from a shell command.
ERROR: Function failed: do_install (log file is located at /export/yocto-intel/meta-intel-iot-devkit/build/tmp/work/x86_64-linux/syslinux-native/6.01-r0/temp/log.do_install.4674)
Todor_M_
Hi Gary,
Do you have these 2 packages installed?
libc6-dev-i386
gcc-multilib
If not please install them, delete the tmp directory and restart the build:
apt-get install libc6-dev-i386 gcc-multilib
Todor_M_
Hi Gary,
Did you copy the build directory from the 32-bit machine to the 64-bit machine? Please try to delete the tmp directory and start the build again?
rm -rf /export/yocto-intel/meta-intel-iot-devkit/build/tmp/
Gary_C_
HI Todor,, This is a fresh repo create on my 64bit machine.. Breaks in the same spot everytime.
Todor_M_
Hi Gary,
libc6-dev-i386
gcc-multilib
Gary_C_
Todor,
Below addressed my issue.  Thanks
Do you have a build guide that documents this kind of stuff when build on a 32 versus a 64 bit build machine?  I never ran into this issue for arm & ppc targets because I was cross-compiling with a cross compiler.
Gary
Todor_M_
Hi Gary,
I personally do not have a build guide. Please refer to the documentation on the DevKit website and if you face any other issues post your questions here. We'll do our best to help.
https://software.intel.com/en-us/iotdevkit
