Software Archive
Read-only legacy content
17060 Discussioni
945GM on a Dell 640m, Panasonic AE900U projector
acap
Principiante
2.287Visualizzazioni
I'm trying to get my Panasonic AE900U projector to work at its native 1280 x 720 resolution. I have the latest drivers from Dell, as Intel's newer drivers won't install. As I type this, I'm in single display mode using the VGA connection to the projector. From what I can tell, the MONINFO is not really picking up the external display, but showing the laptop panel info instead:
Monitor
Windows description......... Generic PnP Monitor
Manufacturer................ AUO
Plug and Play ID............ AUO1247
Serial number............... n/a
EDID data source............ I2C bus (real-time)
Manufacture date............ 2005, ISO week 1
EDID revision............... 1.3
Display type and signal..... Digital
Sync input support.......... n/a
Screen size................. 300 x 190 mm (~15")
Power management............ n/a
Color characteristics
Display gamma............... 2.20
Red chromaticity............ Rx 0.580 - Ry 0.340
Green chromaticity.......... Gx 0.310 - Gy 0.550
Blue chromaticity........... Bx 0.155 - By 0.145
White point (default)....... Wx 0.313 - Wy 0.329
Timing characteristics
VESA GTF support............ Not supported
Horizontal scan range....... n/a
Vertical scan range......... n/a
Video bandwidth............. n/a
Extension blocks............ n/a
Timing recommendation #1.... 1440x900 at 60Hz
Modeline................ "1440x900" 87.600 1440 1488 1520 1600 900 903 909 912 -hsync -vsync
Standard timings supported
n/a
Raw EDID base
00: 00 FF FF FF FF FF FF 00 06 AF 47 12 00 00 00 00
10: 01 0F 01 03 80 1E 13 78 0A 87 C5 94 57 4F 8C 27
20: 25 50 54 00 00 00 01 01 01 01 01 01 01 01 01 01
30: 01 01 01 01 01 01 38 22 A0 A0 50 84 0C 30 30 20
40: 36 00 30 BE 10 00 00 19 00 00 00 00 00 00 00 00
50: 00 00 00 00 00 00 00 00 00 00 00 00 00 FE 00 52
60: 46 39 32 34 00 42 31 34 31 50 57 0A 00 00 00 FE
70: 00 23 31 3D 45 64 8A A6 FF 02 01 0A 20 20 00 E6
Display adapter
Adapter description......... Mobile Intel 945GM Express Chipset Family
Adapter device ID........... 0x27A28086
Display settings............ 1024x768, 16bpp
How can I get an EDID of my AE900U?
Thanks!
-Andrew
17 Risposte
tazdunord
Principiante
(sorry for my english, i'm french...)
I have the same problem: i have a Dell 640m and a Panasonic pt-ax200E projector (1280x720 native resolution) but maximum resolution is 1024x768.
How use 1280x720 on my projector ?
Aaron_B_Intel
Dipendente
Which driver version do you have?
tazdunord
Principiante
Intel Graphics Media Accelerator Driver for Mobile Report
Report Date: 01/29/2008
Report Time[hr:mm:ss]: 20:56:20
Driver Version: 7.14.10.1364
Operating System: Windows Vista Home Premium* , (6.0.6000)
Default Language: French
DirectX* Version: 10.0
Physical Memory: 2037 MB
Minimum Graphics Memory: 8 MB
Maximum Graphics Memory: 224 MB
Graphics Memory in Use: 57 MB
Processor: x86 family 6 Model 15 Stepping 6
Processor Speed: 1997 MHZ
Vendor ID: 8086
Device ID: 27A2
Device Revision: 03
* Accelerator Information *
Accelerator in Use: Mobile Intel 945 Express Chipset Family
Video BIOS: 1264
Current Graphics Mode: 800 x 600 True Color (60 Hz)
* Devices Connected to the Graphics Accelerator *
Non Active Notebook Displays: 1
* Notebook *
Monitor Name: Moniteur Plug-and-Play gnrique
Display Type: Digital
Gamma Value: 2,20
DDC2 Protocol: Supported
Maximum Image Size: Horizontal: Not Available
Vertical: Not Available
Monitor Supported Modes:
1440 x 900 (50 Hz)
1440 x 900 (60 Hz)
Display Power Management Support:
Standby Mode: Not Supported
Suspend Mode: Not Supported
Active Off Mode: Not Supported
* Other names and brands are the property of their respective owners.
MONITOR ASSET MANAGER
Monitor
Hardware information........ n/a
Windows description......... Moniteur non Plug-and-Play gnrique
Display adapter
Adapter description......... Mobile Intel 945 Express Chipset Family
Display settings............ 800x600, 32bpp
User/computer information
Registered user name........ Max
Registered organization..... n/a
Network user name........... Max
Network computer name....... DELL640M
Windows version ............ Windows 2000
Windows build .............. 6.00.6000
Installation date .......... 06/08/2007 12:00:00
Thanks for your help. :)
EDIT : I use DTD Calculator to write DTD to the registry ( 00 00 00 C0 52 D0 1E 20 B8 30 55 40 00 00 00 00 00 1E ) but i can't select 1280x720 with my videoprojector... Have you a solution ?
acap
Principiante
I have the latest Dell will give me: 7.14.10.1114, which appears to be a year old.
This is for Vista Business.
Thanks for your attention, Archibael!
-Andrew
Aaron_B_Intel
Dipendente
That's not a valid DTD (pixel clock is 0MHz).
Aaron_B_Intel
Dipendente
Hmmm... don't know whether drivers that old will work with this technique... Maybe the other poster (who appears to have the same laptop) has a suggestion for how to get Dell to cough up a new one.
With a modern driver, using the DTDCalculator tool mentioned in this Forum's thread on "Custom Resolutions Made Easier", you should be able to force a resolution to appear for this projector. Googling results in several Linux Modelines for this projector:
ModeLine "1280x720" 74.52 1280 1312 1368 1676 720 724 730 750 +hsync +vsync
Modeline "1280x720" 74.71 1280 1320 1368 1640 720 722 724 758 +hsync +vsync
ModeLine "1280x720" 74.5 1280 1312 1368 1676 720 724 730 750 +hsync +vsync
which translates to
1C 1D 00 8C 51 D0 1E 20 20 38 46 00 00 00 00 00 00 1E
2F 1D 00 68 51 D0 26 20 28 30 22 00 00 00 00 00 00 1E
1A 1D 00 8C 51 D0 1E 20 20 38 46 00 00 00 00 00 00 1E
Try one of these in the "Reverse Calculation" tab of the aforementioned tool.
tazdunord
Principiante
Thanks for your help !
(My drivers 7.14.10.1364)
I try with DTD Calculator :
=> VGA don't work
=> Only 800x600 aviable (not 1024x768)
=> VGA don't work
Curious... I don't understand !
Aaron_B_Intel
Dipendente
Specifics about what's not working? Doesn't allow you to choose the resolution, or when you do choose it you get a blank screen?
tazdunord
Principiante
Vga output is not working : when I choose vga output, the screen of the laptop is 800x600 (nothing on the videoprojector ), then returned immediately to 1440x900.
Either the exit vga works but I can only choose 800x600 on my videoprojector .
tazdunord
Principiante
Ihave a anotheur laptop (HP), it's work with the projector in 1280x768.
This is the result of MonInfo :
Monitor
Windows description......... Seiko-Epson Monitor
Manufacturer................ Seiko-Epson
Plug and Play ID............ SEC0000
Manufacture date............ 2003
Screen size................. 330 x 210 mm (~16")
Display gamma............... 2,20
Red chromaticity............ Rx 0,580 - Ry 0,340
Green chromaticity.......... Gx 0,310 - Gy 0,550
Blue chromaticity........... Bx 0,155 - By 0,155
White point (default)....... Wx 0,313 - Wy 0,329
Timing recommendation #1.... 1280x800 at 60Hz
Modeline................ "1280x800" 71,000 1280 1328 1360 1440 800 802 808 823 -hsync -vsync
n/a
Raw EDID base
00: 00 FF FF FF FF FF FF 00 4C A3 00 00 00 00 00 00
10: 00 0D 01 03 80 21 15 78 0A 87 F5 94 57 4F 8C 27
20: 27 50 54 00 00 00 01 01 01 01 01 01 01 01 01 01
30: 01 01 01 01 01 01 BC 1B 00 A0 50 20 17 30 30 20
40: 26 00 4B CF 10 00 00 19 00 00 00 0F 00 00 00 00
50: 00 00 00 00 00 23 87 02 64 02 00 00 00 FE 00 53
60: 41 4D 53 55 4E 47 0A 20 20 20 20 20 00 00 00 FE
70: 00 4C 54 4E 31 35 34 58 31 2D 4C 30 32 0A 00 C8
Display adapter
Adapter description......... Auxiliary port
Adapter device ID........... 0x017610DE
Display settings............ n/a
Registered user name........ n/a
Network user name........... Cat
Network computer name....... COMPAQ
Windows version ............ Windows XP
Windows build .............. 5.01.2600 Service Pack 2
Installation date .......... 18/12/2006 12:00:00
Can you help me ?
Aaron_B_Intel
Dipendente
Unfortunately, I think that EDID block is from the laptop display; I don't think a Panasonic projector would come back as "Seiko-Epson Monitor".
But on the off chance that I'm way off, the DTD for 1280x800 listed is
BC 1B00 A0 50 20 17 30 30 20 26 00 4B CF 10 00 00 19
tazdunord
Principiante
BC 1B00 A0 50 20 17 30 30 20 26 00 4B CF 10 00 00 19 => only 800x600 aviable.
I search the result of Moninfo for my projector with another pc...
Aaron_B_Intel
Dipendente
First, verify with the Search function of regedit that all instances of DTD_1 have been changed to
BC 1B00 A0 50 20 17 30 30 20 26 00 4B CF 10 00 00 19 37 01
and TotalDTDCount is >0.
If that seems to be the case, it's possible your BIOS has been hardcoded to refuse 1280x800... try fooling it with 1278x800:
BC 1BFE A2 40 20 17 30 30 20 26 00 4B CF 10 00 00 19
tazdunord
Principiante
BC 1B00 A0 50 20 17 30 30 20 26 00 4B CF 10 00 00 19 => 1024x768 max
BC 1BFE A2 40 20 17 30 30 20 26 00 4B CF 10 00 00 19 => 1024x768 max
When I try with BC 1B FE A2 40 20 17 30 30 20 26 00 4B CF 10 00 00 19 (and others), DTD say :
"Entered DTD and generated DTD don't match ! " and i'ts changed to BC 1B FE A2 40 20 17 30 30 20 26 00 4B CF 10 00 00 18 (and 1024x768 max)
I try to use 19 in redegit, but it's the same result : 1024x768 max.
Have you an idea ?
Aaron_B_Intel
Dipendente
Afraid I'm not sure what's going wrong, then, tazdunord. Wo0zy on the AVSForum knows a lot more about the DTDCalculator tool, and I'm sure he'd love to help out.
Be sure when you use regedit that you are appending 37 01 to the end of any DTD you place, and have "Hide Modes This Monitor Cannot Display" unchecked in Graphics Properties. Other than that, I'm confused about why it's not working for you.
tazdunord
Principiante
Thanks for your hel Archibael, i'm going to the AVSForum.
norma089
Principiante
intersting thread
Rispondere
