Software Archive
Read-only legacy content
17060 Discussions
Accessing Fortran Common Blocks from C
Intel_C_Intel
I am trying to create a Fortran DLL containing a Common Block which I can then use to link with a C program to resolve an external name.
The DLL appears to create successfully but when I link the C program I always get an unresolved external symbol. This code does work when the Fortran part is not built as a DLL. Does anybody have any ideas ?
I have shown my code below.
Fortran DLL:
!DEC$ DEFINE GLOBAL_EXPORT
block data
include 'GLOBAL01.FI'
data PRBUZ /0.0/
end
GLOBAL01.FI include file:
REAL*8 prbuz
COMMON /GLOBAL01/ prbuz
!DEC$ IF DEFINED (GLOBAL_EXPORT)
!DEC$ ATTRIBUTES DLLEXPORT :: /GLOBAL01/
!DEC$ ELSE
!DEC$ ATTRIBUTES DLLIMPORT :: /GLOBAL01/
volatile /GLOBAL01/
!DEC$ ENDIF
C program:
#include
struct g1 struct
double prbuz;
extern struct g1 global01;
main()
global01.prbuz = 50.0;
When this is linked against the above DLL I always get GLOBAL01 reported as undefined.
Actually, I'd bet that you get _global01 undefined. C is case-sensitive - change the name to GLOBAL01 in the C code and this should work, though I think you also need a _dllimport pragma in there somewhere...
Steve
