Software Archive
Read-only legacy content
17060 Discussions
Add calendar to app
Dominic_Ü_
Hey,
I'm new to XDK and I want to create an app with a calendar in it. I couldn't find any tutorials on this topic for XDK so far.
I only find tutorials where  the guy programmed the calendar from the ground up, that could be a possibility but isn't there something ready to implement?
Is there something like a plug-in and a tutorial how to use that? Maybe it would be possible to use the calendar of the phone itself.
Thanks for any hints!
PaulF_IntelCorp
If you want to use the calendar on the phone you should search for a "cordova phonegap calendar plugin" -- there might be something of value out there.
Dominic_Ü_
Hey thanks! I found one, how can I add this to my project exactly? I found a tutorial but that only explains how to use plugins which are listed inside XDK. The calendar plugin is one I found on the internet and doesn't show in the Plugin list inside of the XDK.
PaulF_IntelCorp
See "importing third-party plugins" section of this doc page > https://software.intel.com/en-us/xdk/docs/add-manage-project-plugins <
Dominic_Ü_
Ok I solved it :) Just in case there is someone clueless like me I'm going to describe how it worked.
First I watched this video: https://www.youtube.com/watch?v=nGuHwzqJI2Y&list=PLPE0R_9gNN0tZmTxCdvfGa7gP5pTElMml Although it looks a bit different now you can reach the PlugIn section from the project folder like described in the video. Then you switch to "Third Party PlugIns". There I just entered the name of the PlugIn as well as the version number. Than just click "Add Plugin" and after a few seconds/minutes it added the PlugIn to the Tutorial.
The PlugIn I used was found on this site: http://cordova.apache.org/plugins/?q=calendar I just copied and pasted the name and version from there to the corresponding fields in the XDK dialog.
Hope this could help someone ;)
