Software Archive
Read-only legacy content
17060 Discussions
Adding IONIC framework in XDK
Kavin_Kumar_S_
Hi All,
Did anyone developed app using IONIC from work in intel XDK ? If so could you please tell me the steps and files to be included ?
Thanks in advance.
Chris_P_Intel
Presently, you have three options.
  1. Make a new project from a sample and choose the Ionic Sample. It is a simple project that is set up to use Ionic.  But it does not leverage the Design view. It's a code-view-only project
  2. Make a new Blank project and elect App Designer. Upon opening the new project, you'll be asked to select a UI framework. Choose Ionic and then start inserting controls and/or editing the code.
  3. Follow the instructions on the ionic website for how to get started with Ionic.
Hope this helps,
Chris
Sebastián_R_
Hi, I couldn't create a IONIC app with Intel XDK. The Ionic Framework Static template generates instead an Game app
Swati_S_Intel1
Hi Sebastian,
There is a bug with the ionic template selected from layout templates. So for now use option #2 suggested by Chris.
Swati
Tomiwa_A_
You can use this Ionic & AngularJS starter for Intel XDK. All it does is get you started in few seconds, just unzip and open the project file in intel xdk. It allows you to take full advantage of Intel XDK's design tool, Ionic Framework and AngularJS. https://github.com/Reinsys/Intel-XDK-Ionic-Starter
Keldon_A_
Did you need to do anything special to create that project? (for reference).
Tomiwa_A_
Keldon A. wrote:
No. Just IntelXDK.
Sunee_Sheikh
Can any one tell me how to add bootstrap add desigener in xdk manually ?
PaulF_IntelCorp
We no longer support App Designer, it has been retired. Please see the release notes.
