Software Archive
Read-only legacy content
17060 Discussions
Admob interstitial after button click?
John_E_2
Hello can someone help me?
Now i have a banner and a interstitial that shows up when i start the app, i want the interstitial to show up after a button click not after 2-3 seconds after app start?
is this possible?
this is the code iam using
<script src='cordova.js'></script>
    <script type="text/javascript">
        var onDeviceReady=function(){
            navigator.splashscreen.hide();
            initAdMob();
            showAdMobInterstitial();
            showAdMobBanner();
        document.addEventListener("deviceready",onDeviceReady,false);
        function initAdMob(){
            if ( window.plugins && window.plugins.AdMob ) {
                var admob_key_banner = "xxxxxx";
                var admob_key_interstitial = "xxxxxx";
                window.plugins.AdMob.setOptions( {
                    publisherId: admob_key_banner,
                    bannerAtTop: false, // set to true, to put banner at top
                    overlap: false, // set to true, to allow banner overlap webview
                    offsetTopBar: true, // set to true to avoid ios7 status bar overlap
                    interstitialAdId: admob_key_interstitial,
                    autoShow: true, // autoshow intertitial Ad
                    isTesting: false // receiving test ad
            } else {
                alert("AdMob plugin not ready");
        function showAdMobBanner(){
            window.plugins.AdMob.createBannerView();
        function showAdMobInterstitial(){
            window.plugins.AdMob.createInterstitialView();
    </script>
Amrita_C_Intel
            initAdMob();
            showAdMobBanner();
You are calling this function inside device ready. what you should actually do is create a button handler, call this function over there.Then you should call the button handler inside device ready.
We have a blank template.Have a look the button responds only when all the ready functions are triggered.
Start a new project -> blank template -> General -> HTML5+Cordova .
Anusha_M_Intel1
Our admob sample actually activates the ads on button click.
The sample ships with the XDK. You can create it by Start a new project -> Samples and Demos -> Genenral -> HTML5+Cordova -> Hello Admob.
It uses the floatighoptspot third party plugin so you will have to build the app, but you can use it for code reference.
Github link: https://github.com/gomobile/sample-hello-admob
