Software Archive
Read-only legacy content
17060 Discussions
After Windows 7 installation, can't start Intel XDK
Stanley_E_
When I tried to start Intel XDK for the first time, I get the error window showing "the intel xdk encountered a problem and must restart"; I have attached the log.
I am trying to run it on a Windows 7 Home Premium, service pack 1 (64-bit OS) laptop. Every attempt afterwards produces the same error.
Any help is appreciated.
PaulF_IntelCorp
Stan -- are you still seeing this problem? If so, have you submitted a crash log? If not, please do. Engineering regularly reviews the crash logs. I see nothing obvious (to me) in the log you provided. Did you try reinstalling the XDK? Also, did you try the EA version, instead? Are you running any form of anti-virus software? Some AV vendors have mistakenly marked the XDK as an infected app, which is not the case.
Stanley_E_
Thanks for the advice. I uninstalled and reinstalled without any success.
I'll check the AV software.
Didn't try the EA version, but I did try an earlier version, 2366, which did work.
Not sure about accessing the crash log, the only log available to me
is the one from "the intel xdk encountered a problem and must restart", which I attached to my original post.
PaulF_IntelCorp
When you get that "must restart" message are you telling the XDK to send the log and including your email address? Engineering will review those logs if you push them.
Stanley_E_
yes, at the time of the crash I sent the logs to support w/ my email address.
PaulF_IntelCorp
Stan -- did you submit with the same email address you're using for the forum? If so, I can ask engineering to look for your crash reports.
Stanley_E_
Thanks for your help, you need not look at my crash log.
I've got XDK (2366) installed on a different machine running Windows 10 and it works.
PaulF_IntelCorp
I've asked engineering to take a closer look.
PaulF_IntelCorp
Stanley -- the problem you are encountering appears to be an anti-virus problem, where the AV software is deleting a key file in the XDK installation directly, which then causes the XDK to crash.
  • What AV software is installed on your system?
  • Is your AV software up-to-date?
  • Can you provide an AV "database version"?
Please let me know, we have been having troubles with some AV vendors falsely marking the XDK as a virus and causing this sort of problem. The more we know about the AV software you are using the more likely we can work with the AV vendor to provide an exception regarding this problem.
