Hi intel.. now all application turn into blank application, a week ago all my application was fine... how do i fix it?
What was the intel xdk update ?
In emulator all looks fine.. but in test and build turns to blank application..
The Intel XDK cache and intel XDK device have been deprecated... so the code for session now is different ?
- Tags:
- HTML5
- Intel® XDK
It's possible, if you were using App Designer, that your index.html files in your projects were corrupted. Please check those files and try creating a new project as a "sanity check" to be sure that things are generally working as normal. Sometimes, when the XDK crashes, it can result in a damaged index.html file.
Topic Options
