Software Archive
Read-only legacy content
17061 Discussions
Android BUILD FAILED
m_messina
My app always has complied correctly.
I didn't compiled it for months. Now, i just tried to compile it and XDK give me the BUILD FAILED message.
The attachments show the compile log.
Does anybody know how to help me?
Thank you
PaulF_IntelCorp
Try updating the CLI version in the Build Settings to 5.4.1 and make sure the "optimize with Crosswalk" box is checked.
m_messina
the CLI version already is 5.4.1 and "optimize with Crosswalk" box is checked
any other suggest?
PaulF_IntelCorp
It is likely being caused by a plugin. I recommend you do the following:
  • make a list of the plugins in your project
  • remove one plugin and attempt to rebuild
  • if the error persists, try above again
  • keep doing this until the build error disappears
Once you find the offending plugin, put the others back (leave out the suspected plugin) to confirm that only the identified plugin is the problem. From there, you can determine the next steps (a different version of the plugin, an alternative plugin, perhaps two plugins are conflicting, etc.).
m_messina
the plugins i'm using now are the same i always used and them always have worked.
Perhaps the only difference is that today i installed and removed the git plugin "j3k0/cordova-plugin-purchase"
I removed it but perhaps somethings is still somewhere.
PaulF_IntelCorp
Did removing that plugin fix the build error?
m_messina
the problem was one of the plugins (androidemail) the until a few month ago correctly worked
removing it the app compile
i don't understand but it is no more compatible
however, problem solved, thanks Paul
