Software Archive
Read-only legacy content
Android emulator with intel image crashes when loading.
Giorgi_Dalakishvili
I installed "Intel x86 Atom System Image" from SDK Manager (API level 15, Android 4.0.3) and Hardware Accelerated Execution Manager but when I try to start intel based avd it crashes in about a minute. The Emulator screen appears with Android animating but than it crashes.
Event log contains this:
Faulting application name: emulator-x86.exe, version: 0.0.0.0, time stamp: 0x5022c7c5
Faulting module name: ig4icd32.dll, version: 8.15.10.1968, time stamp: 0x4acdff49
Exception code: 0xc0000005
Fault offset: 0x000328e0
I am running 64 bit windows 7.
Mohamed_helmi_b_
you must download API 17 or higher
Ahmed_Kchaou
Mohamed_Ali_A_
Easier to use android device then the emulator...
med_anouar_hammami
Bernard
Valued Contributor I
Hi Giorgi,
Can you post the full log file? From the fragment posted by you the error is caused by probably Intel OpenGL library which is part of Intel HD graphics accelerator.Error code points to generic access violation exception which was caused by the executed code at  relative offset 0x000328e0.
Ashwin_S_Ashok
try to update api and sdk version..
and update the adt version...(through eclipse)
JLuna5
Hi, update yu eclipse and download the android last version.
