Software Archive
Read-only legacy content
17060 Discussions
Application Help does not always work
davidgraham
I have a Window PI project, when a dialog box is displayed I can press F1 and the appropriate help is displayed.
This works in most dialogs, but in some cases it does not work.
When it works I get a message of 83 - (#0053) and I call my Help routine, but in other dialogs I am not getting the message 83 when I press F1.
Any ideas why this is going wrong?
David
SUBROUTINE My Program
use dfwin
include 'resource.fd'
interface
integer*4 function ContourProc(hand, message, wPAram, lParam)
!MS$  ATTRIBUTES STDCALL, ALIAS : '_MyProc@16' :: MyProc
integer hwnd, message, wParam, lParam
end function MyProc
end interface
integer*4	iret
iret = DialogBox(hInst,MAKEINTRESOURCE(IDD_MYDLG),hWndMain,LOC(MyProc))
end subroutine MyProgram
integer*4 function MyProc(hwnd, message, wParam, lParam)
!MS$ATTRIBUTES STDCALL, ALIAS : '_MyProc@16' :: MyProc
use dfwin
integer*4	hwnd, message, wParam, lParam
select case (message)
case (#0053)			! WM_HELP
call help       ! displays the correct help topic
case (WM_SHOWWINDOW)
! other code
case (WM_COMMAND)
! other code
end select
end function MyProc
davidgraham
I have worked out why myself.
Its because I didn't have - case (WM_INITDIALOG) - I had deleted it as it didn't appear to do anything!
