Software Archive
Read-only legacy content
17060 Discussions
Automatic Objects
Intel_C_Intel
heres my problem,
When declaring my common statements such as...
common /cmg/ ng,ni(nb),nj(nb),nk(nb), ntsteps(nmax2)
I keep receiving this error...
D:Larryinit.f(10) : Error: A COMMON block data object must not be an automatic object. [NTSTEPS]
I get this error when my values in paranthesis are not hard coded into the program, but user defined (in this case nmax2). How could I declare my matrices in the common statements and still let the user define the value, without receiving this error?
james1
The error message is telling you that any data you place in a COMMON block must be static, meaning that the size must be known at compile time. Space for a COMMON block is not allocated at runtime. Why does this data need to be in a COMMON block?
Intel_C_Intel
I am rewriting a pre-existing program. One parameter that was hard-coded in the program before is now user defined. This parameter sets the size for many arrays, (which is used in many common statements). I just want to know if theres a simple code I can change or if I need to start from scratch. Like, if there is another way i can declare these arrays, where i will not receive this error
james1
You have to get the arrays out of the common block. Once that is done, you can use allocatable arrays to do the job. Whether moving your array out of the common blocks is a big deal depends upon your code, but either you can define a structure to contain the data and pass it around if the number of routines is small, or move these variables to a module and make them public, like global variables, and USE that module in the relevant routines.
James
Intel_C_Intel
How can i declare these structures in a module without a common statement.
james1
Example:
data.f90
module data
integer max_element
integer, allocatable :: global_array(:)
end module data
prog.f90
program main
use data
integer i
max_element = 1000
allocate (global_array(max_element))
do i = 1, max_element
  global_array(i) = i
end do
call sub
end
subroutine sub
use data
type *, global_array(max_element/2)
return
end
Have fun.
James
Jugoslav_Dujic
Valued Contributor II
Just a side warning: if all instances of original common /cmg/ were declared the same (i.e. same types, order & sizes, not necessarily names), James' suggestion will work fine. However, "old masters" sometimes used commons for cheating, i.e. declaring work arrays which were mapped to something else as needed in order to spare memory, kinda:
common /cmg/ ng, ni(nb), nj(nb), nk(nb)
common /cmg/ iwork(3*nb+1)
common /cmg/ ng,array(2*nb)
This kind of spaghetti is hard to unwind if that's the case.
