Software Archive
Read-only legacy content
17060 Discussions
Big packages: locally imported plugins' source code not removed
Luca_F_
I downloaded my app built for Android, ios and Windows platforms and I noticed that their package size was bigger than expected.
Respectively unzipping  apk, ipa and zip files, I found out two problems:
  1. duplicated icons and splashscreen of all platforms are copied into destination www folder (or subfolder).
  2. the source code of my locally imported plugins is not stripped away from the final package.
To fix the first issue, I just placed those images in a folder whose name starts with a dot (i.e. "www\.sys\res\icon\" and "www\.sys\res\screen\"):
so not needed icons and splashscreens are correctly removed from the package.
But I'm not able to remove the plugins source code: if my folder structure is as following
www\plugins\localplugin1\<full source code here>
www\plugins\localplugin2\<full source code here>
in the built package I get
www\plugins\www.localplugin1.id\<platform js here>
www\plugins\www.localplugin2.id\<platform js here>
This issue is present in packages built since the last month.
Is there any workaround (or a post-build command) to "delete" local plugin folders before building the package?
CtwDev
Eric_H_Intel
The plugins should be removed from the build.   I will take a look and get back to you.
Eric
Luca_F_
Any news?
CtwDev
