Software Archive
Read-only legacy content
17060 Discussions
Build Failed with mp-phonegap-plugin-push
Roberto_Z_
Hi, all my build failed when I try to add phonegap plugin push to my project.
I compile the sources for Android, Intel XDK Version: 3641
In attach you can find the build log.
can anyone help me?
Thanx in advance
PaulF_IntelCorp
That plugin will not work with our build system, see this FAQ > https://software.intel.com/en-us/xdk/faqs/cordova#gradle-build-error < unless you perform the changes specified by the following FAQ. Is that what you have done?
Roberto_Z_
Hi Paul, thank for your reply, I'll do what specified in the FAQ but the build still failed, here you can find the attached build log.
I have also attached 2 images: one with config, and one with plugins list.
Do you need some other information?
PaulF_IntelCorp
Roberto -- what happens if you remove those permissions from the build settings page?
Roberto_Z_
Hi Paul, I've tried to remove the add permission in buid config but still build failed error appears.
If I remove the phonegap-plugin-push plugin the  build works ok, it's strange.
Here you can find the build log of the last build failed (without add permession)
Roberto_Z_
Hi Paul, I've tried to remove all the plugins and re-add one by one.
Now it works! Probably there was some problems with conversion from old version of cordova and new 6.2.0
Thanx for your help!
Anthony_H_Intel
Roberto -- Glad you were able to get it working and thanks for letting us know!
