Software Archive
Read-only legacy content
17061 Discussions
Build Stopped working in intel XDK
Peter_S_4
A working project for android and Intel has suddenly stopped building for both platforms.
It appears not to give an error, instead simple stops working? Is it your server as other projects still build ok?
Project Volvo2017
Calling plugman.fetch on plugin ".../cachedPlugins.TttEgK.tmp/cache.IUY2Fh.pl/cordova-plugin-device"
Copying plugin ".../cachedPlugins.TttEgK.tmp/cache.IUY2Fh.pl/cordova-plugin-device" => ".../cordova_project/plugins/cordova-plugin-device"
Calling plugman.install on plugin ".../cordova_project/plugins/cordova-plugin-device" for platform "android
Installing "cordova-plugin-device" for android
Running command: .../cordova_project/platforms/android/cordova/version
Command finished with error code 0: .../cordova_project/platforms/android/cordova/version
Install start for "cordova-plugin-device" on android.
Install complete for cordova-plugin-device on android.
Checking for any plugins added to the project that have not been installed in android platform
No differences found between plugins added to project and installed in android platform. Continuing...
Generating config.xml from defaults for platform "android"
Wrote out Android application name to "Volvo2017"
Wrote out Android package name to "uk.co.volvo.busescoaches2015"
This app does not have launcher icons defined
updated project successfully
Calling plugman.fetch on plugin ".../cachedPlugins.TttEgK.tmp/cache.mGnT7a.pl/cordova-plugin-splashscreen"
Copying plugin ".../cachedPlugins.TttEgK.tmp/cache.mGnT7a.pl/cordova-plugin-splashscreen" => ".../cordova_project/plugins/cordova-plugin-splashscreen"
Calling plugman.install on plugin ".../cordova_project/plugins/cordova-plugin-splashscreen" for platform "android
Installing "cordova-plugin-splashscreen" for android
Install start for "cordova-plugin-splashscreen" on android.
Install complete for cordova-plugin-splashscreen on android.
Calling plugman.fetch on plugin ".../cachedPlugins.TttEgK.tmp/cache.KKo9S5.pl/cordova-plugin-inappbrowser"
Copying plugin ".../cachedPlugins.TttEgK.tmp/cache.KKo9S5.pl/cordova-plugin-inappbrowser" => ".../cordova_project/plugins/cordova-plugin-inappbrowser"
Calling plugman.install on plugin ".../cordova_project/plugins/cordova-plugin-inappbrowser" for platform "android
Installing "cordova-plugin-inappbrowser" for android
Install start for "cordova-plugin-inappbrowser" on android.
Install complete for cordova-plugin-inappbrowser on android.
Calling plugman.fetch on plugin ".../cachedPlugins.TttEgK.tmp/cache.EqDd93.pl/cordova-plugin-statusbar"
Copying plugin ".../cachedPlugins.TttEgK.tmp/cache.EqDd93.pl/cordova-plugin-statusbar" => ".../cordova_project/plugins/cordova-plugin-statusbar"
Calling plugman.install on plugin ".../cordova_project/plugins/cordova-plugin-statusbar" for platform "android
Installing "cordova-plugin-statusbar" for android
Install start for "cordova-plugin-statusbar" on android.
Install complete for cordova-plugin-statusbar on android.
Calling plugman.fetch on plugin ".../cachedPlugins.TttEgK.tmp/cache.x1RLXF.pl/cordova-plugin-compat"
Copying plugin ".../cachedPlugins.TttEgK.tmp/cache.x1RLXF.pl/cordova-plugin-compat" => ".../cordova_project/plugins/cordova-plugin-compat"
Calling plugman.install on plugin ".../cordova_project/plugins/cordova-plugin-compat" for platform "android
Installing "cordova-plugin-compat" for android
Install start for "cordova-plugin-compat" on android.
Install complete for cordova-plugin-compat on android.
Calling plugman.fetch on plugin ".../cachedPlugins.TttEgK.tmp/cache.TbDGT7.pl/cordova-plugin-file"
Copying plugin ".../cachedPlugins.TttEgK.tmp/cache.TbDGT7.pl/cordova-plugin-file" => ".../cordova_project/plugins/cordova-plugin-file"
Calling plugman.install on plugin ".../cordova_project/plugins/cordova-plugin-file" for platform "android
Installing "cordova-plugin-file" for android
Dependencies detected, iterating through them...
Plugin dependency "cordova-plugin-compat" already fetched, using that version.
Dependent plugin "cordova-plugin-compat" already installed on android.
Install start for "cordova-plugin-file" on android.
Install complete for cordova-plugin-file on android.
The Android Persistent storage location now defaults to "Internal". Please check this plugins README to see if you application needs any changes in its config.xml.
If this is a new application no changes are required.
If this is an update to an existing application that did not specify an "AndroidPersistentFileLocation" you may need to add:
      "<preference name="AndroidPersistentFileLocation" value="Compatibility" />"
to config.xml in order for the application to find previously stored files.
Calling plugman.fetch on plugin ".../cachedPlugins.TttEgK.tmp/cache.jOKjei.pl/cordova-plugin-file-transfer"
Copying plugin ".../cachedPlugins.TttEgK.tmp/cache.jOKjei.pl/cordova-plugin-file-transfer" => ".../cordova_project/plugins/cordova-plugin-file-transfer"
Calling plugman.install on plugin ".../cordova_project/plugins/cordova-plugin-file-transfer" for platform "android
Installing "cordova-plugin-file-transfer" for android
Plugin dependency "cordova-plugin-file" already fetched, using that version.
Dependent plugin "cordova-plugin-file" already installed on android.
Install start for "cordova-plugin-file-transfer" on android.
Install complete for cordova-plugin-file-transfer on android.
Calling plugman.fetch on plugin ".../cachedPlugins.TttEgK.tmp/cache.KVTytV.pl/cordova-plugin-file-opener2"
Copying plugin ".../cachedPlugins.TttEgK.tmp/cache.KVTytV.pl/cordova-plugin-file-opener2" => ".../cordova_project/plugins/cordova-plugin-file-opener2"
Calling plugman.install on plugin ".../cordova_project/plugins/cordova-plugin-file-opener2" for platform "android
Installing "cordova-plugin-file-opener2" for android
Install start for "cordova-plugin-file-opener2" on android.
Updating build files since android plugin contained <framework>
Install complete for cordova-plugin-file-opener2 on android.
Calling plugman.fetch on plugin ".../cachedPlugins.TttEgK.tmp/cache.Ke3PFJ.pl/cordova-plugin-whitelist"
Copying plugin ".../cachedPlugins.TttEgK.tmp/cache.Ke3PFJ.pl/cordova-plugin-whitelist" => ".../cordova_project/plugins/cordova-plugin-whitelist"
Calling plugman.install on plugin ".../cordova_project/plugins/cordova-plugin-whitelist" for platform "android
Installing "cordova-plugin-whitelist" for android
Install start for "cordova-plugin-whitelist" on android.
Install complete for cordova-plugin-whitelist on android.
               This plugin is only applicable for versions of cordova-android greater than 4.0. If you have a previous platform version, you do *not* need this plugin since the whitelist will be built in.
Checking config.xml for saved platforms that haven't been added to the project
Checking config.xml for saved plugins that haven't been added to the project
************* Processing the main config.xml file (after_prepare)  *****************
App Directory = [.../cordova_project]
Will process and update the following config files:
    Config.xml = [.../cordova_project/config.xml]
Namespaces:
    prefix/uri ''/'http://www.w3.org/ns/widgets'
    prefix/uri 'intelxdk'/'http://xdk.intel.com/ns/v1'
Android Manifest Namespaces:
    prefix/uri 'android'/'http://schemas.android.com/apk/res/android'
Name of the app is [Volvo2017]
Updating full app name to [Volvo2017]
Processing preference android-minSdkVersion [14]
Processing preference android-targetSdkVersion [23]
Processing preference android-installLocation [auto]
Processing preference permissions
Updating the versionCode
Updating the versionName
Processing debuggable
Added [{http://schemas.android.com/apk/res/android}debuggable] with [true]
PaulF_IntelCorp
I just tried an Android build and it worked without any issues. Are you still having trouble?
p.s. I notice you have set the android-targetSdkVersion to 23 (corresponds to the Target Android API in the Build Settings), which is not recommended unless you have a plugin that absolutely requires that setting. I recommend you use 21. Your app will still be installable on Android 6+ devices with a setting of 21, this number does not control the upper version of Android, it specifies the compatibility shims that are put in place to insure best operation of your app. With Cordova 6.2.0 the recommended target API is 21, this is the version of Android the code was tested against, which is what the number really represents.
Peter_S_4
Yes still having issues, other builds for other projects still work, its this project alone that has stooped over night with no code changes.
The settings have all worked 100% for weeks, no changes to any version numbers. It also fails for IOS and androind.
I have tested the package route using Phonegaps build servers and it works, so something on your cloud server is failing for this particular build?
PaulF_IntelCorp
If it's for all build targets and only that project I suspect it is a project-specific issue, not a build server issue. Can you share a ZIP of the project (privately) so I can try building it? I'll send you a private message.
