Software Archive
Read-only legacy content
17060 Discussions
Build error,Unable to build. Http request failed.
Vysoft_G_
I tried to build a app for iOS. I tried downgrading to 4.1.2. But the message: Build error, Please verify that you have internet connection. Http request failed. It builds and uploads for hours. But then it says the error. Are there any ideas?
Anusha_M_Intel1
I believe when you downgrade to 4.1.2 it updated the plugins folder. It downloads the plugins again. And it is not able to do so due to some connectivity issue. Are you behind a company or local system proxy?
Vysoft_G_
I'm behind a local system proxy.
Sauriol_y_
I have the same problem, i want export my rpg maker mv ios game when result :Unable to build. Please verify that you are connected to the internet and try again.
Http request failed
Anusha_M_Intel1
@Vysoft and @Sauriol: I suggest adding nw.exe to your proxy exceptions list.
Elite_P_
Hey how you doing ?
I got exactly the same problem as you and i just resolved it !
You said that you use RPG Maker MV.
When you export your project, ALL the files of RPG Maker are exported too, so your folder 'www' will be easily "300mb".
I deleted all the files that was useless and my folder was back to 70mb and then when i reclick 'build' it worked !
But after i got another probleme : "Intel XDK The build failed. An error occurred while building the application. Verify your build assets are correct and try again."
The only thing i did was restart my Intel XDK and it worked !
Hope i helped you.
(Sorry for my English)
