hol cree una aplicacion que me crea una base de datos y dentro de ella crea una tabla y me inserta registros dentro de ella, para esto uso html5 websql + cordova.
Pero no encuentro la base de datos cuando instalo mi app en mi movil, esta app funciona bien , estoy rooteado supuestamente deberia estar en data/data , la busco en todo el movil y no la encuentro.
o debo usar exclusivamente un plugin sqlite y no usar websql ?
alguien me puede ayudar
I'm not quite sure I understand everything, google translate may have confused things for me, I'm not 100% sure where the database is being stored, but I suspect it may not be under your project directory, so it would not be part of the package. I think you'd need to create it the first time it runs on a particular device.
One other thing I noticed, It looks like WebSQL may not be further developed:
https://www.w3.org/TR/webdatabase/
http://stackoverflow.com/questions/7183049/how-to-delete-a-database-in-websql-programmatically
You might want to look into IndexedDB or even a Cordova plugin.
Am I understanding the question correctly?
Dale
I recommend you use the SQLite plugin, many developers have had very good results with that plugin.
