HI all I would like a simple full C# example on how to handle OnFiredGesture. All I want is to get the "fist" , "spreadfingers" and "v_sign" gestures , Nothing else :) .NB: I'm using the F200 camera
The documentation is not clear on how to implement it.
pxcmStatus OnModuleProcessedFrame(Int32 mid, PXCMBase module, PXCMCapture.Sample sample) { // check if the callback is from the hand tracking module if (mid==PXCMHandModule.CUID) { // Retrieve the current hand data handData.Update(); // Process hand data } // return NO_ERROR to continue, or any error to abort return pxcmStatus.PXCM_STATUS_NO_ERROR; }
You can find the sample codes @https://software.intel.com/sites/landingpage/realsense/camera-sdk/v1.1/documentation/html/manuals_handling_gestures.html under "Creating and Registering a Gesture Handler". Thanks!
David Lu (Intel) wrote:
You can find the sample codes @https://software.intel.com/sites/landingpage/realsense/camera-sdk/v1.1/d... under "Creating and Registering a Gesture Handler". Thanks!
Hi Thanks for the reply... that's actually where I found the sample code in my question :\ ... I realised the C# example is incorrect. I guess I will have to wait until they fix it or use the java example and convert it into C#
