I'm having no luck getting any of the Unity samples to work. When I try to build one of the Sample Unity projects, and I select a directory for the target EXE, I get an error about Unity not being able to accept relative paths when I try to Build and Run.
As another test I cloned this Git repository for a RealSense enabled Jenga game from OuthouseGames, who were kind enough to share the source during one of Intel's wonderful developer webinars:
https://github.com/OuthouseGames/realsense-jenga
This does compile and run but when it runs, I see the main screen which seems active. However, there's a medium size light gray square in the upper left corner that I'm guessing is where the RealSense video stream is supposed to appear. Nothing ever appears in that square and the the app fails to respond to hand gestures or any other movement.
I know my F200 is working because I have written a large app around it that works fine, and the other non-Unity samples work fine too. I do have the latest Unity 3D installed and the project editor does work fine. I just can't seem to get any Unity apps to work. Does anybody have any ideas for me to try so I can get Unity 3D/RealSense working on my development station?
How did you build those Unity sample apps? You should copy those apps to somewhere else and build. Please let me know if you still have such issue. Thanks!
