When trying to start XDK on Windows 7, I get the login error - "unknown user". The credentials are the same I use to the developer zone.
Any help would be greatly appreciated.
Thanks!
- Tags:
- HTML5
- Intel® XDK
It is difficult to say why. Still you can check your firewall settings.
Unfortunately, at this time, we do not have a unified login between the developer zone and the XDK. We had hoped to have this in place earlier this year, but we are still waiting for some internal network changes to be made that will allow us to do this. Our goal is to unify these logins, but we are not able to at this time. Sorry for that difficulty.
p.s. If you are having trouble creating a login for the XDK, please visit http://appcenter.html5tools-software.intel.com
Finally working inside the Intel XDK
XDK-what a great tool--!
Now about App Framework? is it Intel's stand-alone framework for HTML5?
I have 11 apps written with BBUI.js ( Blackberry's JavaScript/html5/css framework-no cordova ) also have same apps in JQM. what can App Framework give me?
App Framework is optimized for mobile devices, especially webviews, and fixes a lot of UI issues, especially on Android and a few on iOS and Windows Phone 8. You are not required to use App Framework; it is an open source UI library and is supported by Intel.
Your BBUI.js is probably a good library to continue using, as it has also been optimized for mobile (but I have no direct experience). However, despite the name, many people find JQM does not work well in a webview (embedded browser) environment. App Framework would be a good consideration as a replacement for JQM. You can use jQuery with App Framework, just make sure to follow the instructions on this page for using the App Framework UI library with the jQuery library: http://app-framework-software.intel.com/documentation.php#afui/afui_jquery
<script src="jquery.js"></script> <script src="jq.appframework.js"></script> <script src="appframework.ui.js"></script>
I believe there will be a change in the next version that combines the last two libraries into one, watch the github repo for details.
I can't login xdk on my win7. why?
Its not the login details of software.intel ... actually you need to sign up for XDK too. So, sign up for XDK there itself and then login with those details.
xdk:client (1411971745310): Intel XDK: 1332
xdk:client (1411971745311): Platform: win32-ia32 (6.1.7600)
xdk:client (1411971745354): Starting client process initialization
xdk:server (1411971746029): Starting server process initialization
xdk:server (1411971748848): Http server started on the standard port 58889
xdk:server (1411971748854): Component "core:assert" starting import
xdk:server (1411971748855): Component "core:assert" finished initialization
xdk:server (1411971748855): Component "core:component-error" starting import
xdk:server (1411971748855): Component "core:component-error" finished initialization
xdk:server (1411971748855): Component "core:command-line-options" starting import
xdk:server (1411971748855): Component "core:command-line-options" finished initialization
xdk:server (1411971748855): Component "core:service-error" starting import
xdk:server (1411971748856): Component "core:service-error" finished initialization
xdk:server (1411971748856): Component "core:buffer" starting import
xdk:server (1411971748856): Component "core:buffer" finished initialization
xdk:server (1411971748856): Component "core:signaler" starting import
xdk:server (1411971748859): Component "core:signaler" finished initialization
xdk:server (1411971748859): Component "core:signaler-group" starting import
xdk:server (1411971748862): Component "core:signaler-group" finished initialization
xdk:server (1411971748862): Component "core:logger" starting import
xdk:server (1411971748863): Component "core:logger" finished initialization
xdk:server (1411971748863): Component "core:http-request" starting import
xdk:server (1411971748867): Component "core:http-request" finished initialization
xdk:server (1411971748867): Component "core:database" starting import
xdk:server (1411971748868): Component "core:database" finished initialization
xdk:server (1411971748868): Component "core:version" starting import
xdk:server (1411971748868): Component "core:version" finished initialization
xdk:server (1411971748868): Component "core:userfs-name-converter" starting import
xdk:server (1411971748869): Component "core:userfs-name-converter" finished initialization
xdk:server (1411971748869): Component "core:crash-handler" starting import
xdk:server (1411971748871): Component "core:crash-handler" finished initialization
xdk:server (1411971748871): Component "core:i18n-support" starting import
xdk:server (1411971748871): Component "core:i18n-support" finished initialization
xdk:server (1411971748872): Component "server:userfs" starting import
xdk:server (1411971748883): Component "server:userfs" calling init()
xdk:server (1411971748933): Component "server:userfs" finished initialization
xdk:server (1411971748933): Component "server:user-profile" starting import
xdk:server (1411971748937): Component "server:user-profile" calling init()
xdk:server (1411971748937): Component "server:user-profile" finished initialization
xdk:server (1411971748938): Component "server:projectInfo" starting import
xdk:server (1411971748939): Component "server:projectInfo" calling init()
xdk:server (1411971748939): Component "server:projectInfo" finished initialization
xdk:server (1411971748939): Component "server:ui-builder" starting import
xdk:server (1411971749008): Component "server:ui-builder" calling init()
xdk:server (1411971749010): Component "server:ui-builder" finished initialization
xdk:server (1411971749010): Component "server:emulator-notification" starting import
xdk:server (1411971749015): Component "server:emulator-notification" calling init()
xdk:server (1411971749015): Component "server:emulator-notification" finished initialization
xdk:server (1411971749016): Component "server:emulator-webserver" starting import
xdk:server (1411971749017): Component "server:emulator-webserver" calling init()
xdk:server (1411971749018): Component "server:emulator-webserver" finished initialization
xdk:server (1411971749018): Component "server:new-project-creator" starting import
xdk:server (1411971749023): Component "server:new-project-creator" calling init()
xdk:server (1411971749023): Component "server:new-project-creator" finished initialization
xdk:server (1411971749023): Component "server:zip-util" starting import
xdk:server (1411971749027): Component "server:zip-util" calling init()
xdk:server (1411971749027): Component "server:zip-util" finished initialization
xdk:server (1411971749027): Component "server:uuid-server" starting import
xdk:server (1411971749032): Component "server:uuid-server" calling init()
xdk:server (1411971749032): Component "server:uuid-server" finished initialization
xdk:server (1411971749032): Component "server:app-starter" starting import
xdk:server (1411971749041): Component "server:app-starter" calling init()
xdk:server (1411971749044): Component "server:app-starter" finished initialization
xdk:server (1411971749044): Component "server:force-download" starting import
xdk:server (1411971749048): Component "server:force-download" calling init()
xdk:server (1411971749048): Component "server:force-download" finished initialization
xdk:server (1411971749048): Component "server:updater" starting import
xdk:server (1411971749056): Component "server:updater" calling init()
xdk:server (1411971749057): Component "server:updater" finished initialization
xdk:server (1411971749057): Component "server:editor-node" starting import
xdk:server (1411971749112): Component "server:editor-node" calling init()
xdk:server (1411971749113): Component "server:editor-node" waiting for delayed initialization
xdk:server (1411971749113): Component "server:cordova" starting import
xdk:server (1411971749125): Component "server:cordova" calling init()
xdk:server (1411971749440): Component "server:cordova" finished initialization
xdk:server (1411971749440): Component "server:api-explorer" starting import
xdk:server (1411971749445): Component "server:api-explorer" calling init()
xdk:server (1411971749472): Component "server:api-explorer" finished initialization
xdk:server (1411971749472): Component "server:editor-node" finished delayed initialization
xdk:server (1411971749473): Component "server:projectInfo" calling start()
xdk:server (1411971749473): Component "server:projectInfo" finished start()
xdk:server (1411971749473): Component "server:ui-builder" calling start()
xdk:server (1411971749476): Component "server:ui-builder" finished start()
xdk:server (1411971749476): Component "server:emulator-webserver" calling start()
xdk:server (1411971749477): Component "server:emulator-webserver" finished start()
xdk:server (1411971749477): Component "server:editor-node" calling start()
xdk:server (1411971749479): Component "server:editor-node" finished start()
xdk:server (1411971749480): Intel XDK is initialized now
xdk:server (1411971749481): Writing to the server data file
editor:server (1411971749484): Startup complete, serving on port: 55269
xdk:server (1411971749486): Wrote server data to "C:\Users\e-dishub1\AppData\Local\XDK\server-data.txt"
xdk:client (1411971749663): Successfully read server data file
xdk:client (1411971749804): Client cannot validate with server (status=0)
[Log closed from xdk:client]
my xdk cant start, why?
Are you able to log into app center with your browser? Go here http://appcenter.html5tools-software.intel.com to confirm your userid and password. Note that the userid and password you use for this forum is not the same userid and password. Eventually they will be the same, but now they are different.
I can´t register in :c
But I can login opened the application without opening it to open as administrator
No puedo registrame en
Pero puedo abri la aplicaciuon si la ejecuto como adminiistrador
I do not understand what this means: "But I can login opened the application without opening it to open as administrator" my translation of "Pero puedo abri la aplicaciuon si la ejecuto como adminiistrador" comes out as "But I can opened the application if I run as administrator" -- which leads me to believe that you cannot run the XDK unless you are logged in as administrator. Is this correct?
Did you install the XDK into a location other than that suggested by the installer? If so, please reinstall into the standard location, which is a local user location.
Since you cannot log into the App Center, it sounds like the userid and password you are using with the XDK are different than those you registered with.
Can anybody help me on registration process for xdk
What email address are using to register with?
Where are you trying to create your account? Have you tried creating it inside the XDK?
when i try to login in my intel xdk application it shows access denied . pls help me
Can you post a screenshot of the error you are seeing?
Are you behind a firewall/proxy at all?
i can't launch intel xdk no icon my desktop.
I have successfully installed intel xdk on my computer windows 7 64 bits
any idea?
any idea?
Press the 'Win' button and type 'Intel XDK'. From that result, create a shortcut on your desktop.
Sandeep, could you start a separate thread giving more information on the assistance you need?
I can't start the intel_ xdk application.When ever i try to start it an message shows up that says "the application did not start correctly". I uninstalled it and then installed it but again I faced the same problem.
