Software Archive
Read-only legacy content
17060 Discussions
Cannot access more than 3 styles in Design interface
Nick_F_2
New Contributor III
I have more than 3 styles listed under custom styles.
When I expand the drop down only 2.5 styles are visible anything below that are not selectable.
Anusha_M_Intel1
Hi Nick,
I am able to reproduce the same problem. I will let the responsible engineers know about this so it can be fixed. In the meantime, as a temporary workaround, you can select any of the styles which expands the 'Active Styles' area and you can view a longer drop down (see attached image).
Chris_P_Intel
In the interim, just select a style, that'll make the whole style window bigger, and then you should be able to choose whichever you want. You can remove a style by clicking its 'x'.
