Software Archive
Read-only legacy content
17060 Discussions
Changing the FPS
Mona_J_
I have used the following code to change the FPS but it only has 3 options (COARSE, MEDIAN and FINEST). I am wondering if I can set the fps to something greater than say 60fps or if I can set it to any other number else than 50,55 or 60fps (ex:30fps?)
Can you please walk me through the process by some sample code?
PXCMCapture.Device device = senseManager.captureManager.device;
device.SetIVCAMAccuracy(PXCMCapture.Device.IVCAMAccuracy.IVCAM_ACCURACY_FINEST);
Mona Jalal.
Xusheng_L_Intel
You can use EnableStream(StreamType stream, pxcI32 width, pxcI32 height, pxcF32 fps) if you want to set the fps.Thanks!
Xusheng_L_Intel
Mona_J_
Hi David,
Does using  PXCMCapture.Device device = senseManager.captureManager.device;
Also set the fps to one of the 50, 55, or 60 fps values?
