Hi!
Ive made a dummymodule in which ive included a global commonareadefinition through an include-statement.
like this
module Commonarea
INCLUDE MyCommonArea.for'
contains
subroutine dummy
end subroutine dummy
end module Commonarea
The reason for this is to be able to use the commonarea in both *.for and *.f90-files.
In one of the subroutines in my program Im storing the common in an unformatted file. Ive created a huge integerarray and using an equivalencestatement between the first item in the integerarray and the first item in the common to map the memory into my integerarray.
If im using the Use-statement, this doesnt work, but if Im using INCLUDE MyCommonArea.for' instead then it works
Ex:
subroutine test
! Alt 1, not working
USE Commonarea
! Alt 2, working
integer inrArr(10000)
equivalence(FirstItemInCommon, intarr(1) )
!StartOfCode
intNo = 1 ! DummyCode
end subroutine test
Can anyone explain the difference or suggest a solution to my problem.
/Martin
like this
module Commonarea
contains
subroutine dummy
Ex:
subroutine test
USE Commonarea
! Alt 2, working
!StartOfCode
end subroutine test
/Martin
The COMMON you define in the MODULE is not the same as the one that's INCLUDEd directly. Remember that INCLUDE is just source substitution.
Why don't you use the USE statement in your *.for files? It will work fine.
Steve
Steve
