Software Archive
Read-only legacy content
17061 Discussions
Como puedo actualizar...
Juan_Eduardo_Brennan
Hola, utilizo el Interl XDK Versión 1826.
Cuando pruebo las aplicaciones lo hago con el Intel App preview en android y en iphone
pero me aparecen muchas aplicaciones que ya no tengo en el INTEL XDK, como hago para
poder actualizar esto?
Gracias.
John_H_Intel2
I am not really sure I understand. Do you have the XDK installed on your computer? Are you trying to test Intel App Preview that you can install from the stores? We previously had a Legacy version available, which has recently been removed from the stores.
Hi, Yes, I have the XDK installed on my computer and my phone the app preview.
When I log on the server shows me applications that are no longer in my XDK, which were tests that have eliminadoen the app preview continue.
The question is, should only upgrade?
Thank You.
John_H_Intel2
Log into appcenter.html5tools-software.intel.com on your computer using the same login that you use for the XDK. From here can remove old projects from the server.
Thanks for U help!!!
