Software Archive
Read-only legacy content
17060 Discussions
Connection to socket.io impossible
yarek_c_1
My application works fine on browser.
When I compile it with intelXDL / phonegap : AJAX calls works fine, but not socket.io connections. (sockets use port 1445)
I have
"status: cancelled"
so it looks like permissions problem
permissions problems
I tried to add ALL possible combinations for whitelist (I use CLI 4.1.2)
    http://www.example.com/*
    http://www.example.com:1445/*
    http://*:1445/*
    http://*
The first rule makes AJAX call possible. The other rules do not allow to connect to socket.io on port 1445
Any idea ?
PaulF_IntelCorp
Yarek, are you trying this with an Android build or with a Crosswalk build? I'm suspecting that you are using an older Android device that does not support what you are trying to do. Build with Crosswalk and see how that works.
Eliecer_R_
lograron Solucionar? tengo el mismo problema
