Community
cancel
Showing results for
Search instead for
Did you mean:
Phuoc_H_
Construct 2, cannot to install apk file.
hello every one.
I had a project and It worked well. I used construct 2 to make it and used Intel XDK to build. Now, when I used new intel XDK to build it, the "BUILD COMPLETE" but I can't install file apk on my phone (android 4.0).
Tags (2)
PaulF_IntelCorp
Phuoc -- I'm unable to see the images you provided with your post. You can attach them to your post using the "Attach Files to Post" link below the edit window, that will insure that blocked sites do not get in the way.
Have you enabled "side-loading" on your Android device? See this Google search for help on that item.
