I tried Crosswalk build version 7 because I needed old Android engine (bellow 4.4) that allows the "target-densitydpi=device-dpi".
Then it turned out it does not run the meta tag also but something interesting happened, when I used window.open an internal web browser poped- out and it used this tag and everything looked nice. The problem is that I couldn't use any of the plug- ins.
Is there a way to build an app using this browser as default but also to be able to use the plug- ins? Or is there another way to build an app that allows this meta tag?
- Tags:
- HTML5
- Intel® XDK
Try your experiment using Crosswalk 11 or 12 or the shared mode option (which currently uses 14).
Topic Options
