Software Archive
Read-only legacy content
17060 Discussions
Default architecture for Pentium III
Intel_C_Intel
I just installed the 6.5/6.5a update to my computer and I read that there is a /arch:p6p compiler switch that can optimize for the Pentium III. I found where to add this for individual programs, is there a way I can make this compiler option permanent? I tried to save the Fortran environment with this switch included, but the next time I load up a file, the switch is not activated. I've looked through the help file but it really doesn't cover this in any great detail. Thanks, Mitch
I can't reproduce this problem - saving /arch:p6p in a saved environment and then using it on a new project works for me.
May I suggest using /arch:host (and /tune:host) instead? Or, better, you can use /fast ("Generate most optimal code") which is shorthand for /arch:host/tune:host/noaccuracy_sensitive/math_library:fast/align:dcommons.
Steve
Intel_C_Intel
When you save the environment it asks to "Save Fortran Console Environment as". I've tried a few different names, but the next time I load a new file from scratch, all modifications to the /arch or /fast are gone. I look in the "Manage Saved Environments" area and see the ones I saved, but can't figure out how to use that particular environment automatically when loading in new files. Sorry for all the inconvenience. Thanks again, Mitch
Saved environments are used when you create a new project - not when loading an existing one or adding files to an existing one. If, when you create a project, you have a saved environment of the right kind (Console, etc.), you'll get an additional prompt asking if you want to apply a saved environment.
Steve
