Software Archive
Read-only legacy content
17060 Discussions
Depth Stream is not Working
Deepak_k_
hi,
i converted depth stream into mat variable in opencv.
when i run the code it runs successfully. but nothing is shown in the screen. and after few second the screen become black.
I am not able to figure out what mistake i am doing.
below is the code :
int wmain(int argc, WCHAR* argv[])
    //Create the IplImage headers
    IplImage* depthimg = cvCreateImageHeader(cvSize(320, 240), 16, 1);
    // create the PXCSenseManager
    PXCSenseManager *psm=0;
    psm = PXCSenseManager::CreateInstance();
    if (!psm) {
        wprintf_s(L"Unable to create the PXCSenseManager\n");
        return 1;
    // select the color stream of size 640x480 and depth stream of size 320x240
    psm->EnableStream(PXCCapture::STREAM_TYPE_DEPTH, 640, 480);
    // initialize the PXCSenseManager
    if(psm->Init() != PXC_STATUS_NO_ERROR) return 2;
    PXCImage *colorIm, *depthIm;
    for (int i=0; i<MAX_FRAMES; i++)
        if (psm->AcquireFrame(true)<PXC_STATUS_NO_ERROR) break;
        // retrieve all available image samples
        PXCCapture::Sample *sample = psm->QuerySample();
        // retrieve the image or frame by type from the sample
        depthIm = sample->depth;
        PXCImage *depth_image = depthIm;
        PXCImage::ImageData depthImageData;
        depth_image->AcquireAccess( PXCImage::ACCESS_READ, &depthImageData );
        cvSetData( depthimg, (short*)depthImageData.planes[0], depthimg->width * sizeof(short) );
        Mat depthMat(depthimg );
        imshow( "depth", depthMat );
        depth_image->ReleaseAccess(&depthImageData);
    waitKey();
thanks !!
