Software Archive
Read-only legacy content
Disable Stream
FLeac
I am using the realsense sdk to develop a 3d scan software that doesn't need textures but only the Depth stream. I want to know if it is possible to disable the rgb stream. I know that it is possible to enable a stream using EnableStream method in SenseManager, for example:
sm->EnableStream(PXCCapture::StreamType::STREAM_TYPE_DEPTH, 640, 480, 60);
But is it possible to do the opposite?
jb455
Valued Contributor II
Can you just not enable the colour stream? Or does it do it anyway when you enable the 3D scan?
I think if you save the model as a PLY or STL file (or OBJ with texture file enabled though you may have to fiddle with it a bit so it doesn't look for the texture) it'll just save the geometry and not the colours - same result but different solution.
FLeac
Nope even if I don't enable the color stream the saved file has a material with the "right" color..
