Software Archive
Read-only legacy content
17060 Discussions
Disabling MemoryDown
JONG_L_
I have a custome board, which is similar to MinnowBoard MAX.
In order to build firmware for my board I downloaded/installed Intel Firmware Engine 1.1, and built firmware without MemoryDown option since my board uses SODIMM module.
If MemoryDown is disabled, does firmware read the SPD from SODIMM module and then set memory parameters accordingly? or am I still responsible to set all other memory parameters(such as Ranks, tCL, etc)?
Jong
BrianRichardson
You should be able to just change the "Enable Memory Down" option in the MemoryInit module from "1" to "0". This will ignore any manual memory settings and use the SPD values (assuming SMBUS is routed properly to the DIMM slots). Please try this and let me know if it works.
JONG_L_
Thank you, Brian.
It works exactly what you stated.
Jong
BrianRichardson
Excellent. Glad I could help.
