ERROR ITMS-90101 "The bundle does not support one or more of the devices supported by the previous app version. Your app must continue to support all devices previously supported"
I cannot seem to find a place where I can change the device family target in build settings?
The only update i made to the app was updated the Cordova CLKI version and updated / changed provisioning profiles and certificate.
Your help will be greatly appreciated!
Darren -- I suspect you may have to twiddle the Cordova "target-device" option in the intelxdk.config.additions.xml file. See this sample file for some help > https://github.com/gomobile/sample-hello-cordova/blob/master/intelxdk.config.additions.xml#L105 <
Adding something like the following will allow you to manipulate that option for your iOS build:
<platform name="ios"> <!-- to select between building for iPhone, iPad or both --> <!-- https://cordova.apache.org/docs/en/5.4.0/guide/platforms/ios/config.html --> <!-- valid values are handset, tablet and universal --> <preference name="target-device" value="universal" /> </platform>
Of course, which setting you use depends on the prior store build, so you might have to experiment to figure out which is the correct setting.
