Software Archive
Read-only legacy content
17060 Discussions
Email Client
Alexander_F_
Hi, I trying to build an app that be able to send and receive email without use the native client installed in the phone... I try this with socket connection but at the moment is not good results because can not connect to the server... any idea of a plugin or a way how I can do that, I appreciate all the ideas that you can provide me.
Thanks in advance.
Diego_Calp
Valued Contributor I
You will always need a server to send and receive emails. What so you mean about you cannot connect to server?
One possibility to bypass the device email client is call by ajax a php in a server that send o read emails.
Diego
Alexander_F_
Okay I go to give you more details, the problem is that this application must send and receive emails but we do not have the port 80 open we have only the port 25 open, then the only server available is mail server... by the way can not use Ajax, I try using this plugin https://github.com/blocshop/sockets-for-cordova but the phone do not let me connect by socket, then I need another way to do that.
Thank You by your response.
id559249638859odr
