Software Archive
Read-only legacy content
17060 Discussions
Error: A license for CCompL is not available now (-15,570,115)
paul_c_9
Hi
Our license is in date but when we execute the build install command on linux redhat
-bash-4.1$ build install
Building: _tools/bin/wrapshell from /net/dubnfs01/release/product_maintenance/FW/FW8/FW_8.1.x/releases/FW_8.1B799/FusionWorks/BuildTools/tools/wrapshell.c
Error: A license for CCompL is not available now (-15,570,115).
A connection to the license server could not be made. You should
make sure that your license daemon process is running: both an
lmgrd process and an INTEL process should be running
if your license limits you to a specified number of licenses in use
at a time. Also, check to see if the wrong port@host or the wrong
license file is being used, or if the port or hostname in the license
file has changed.
License file(s) used were (in this order):
1. Trusted Storage
    • 2. /opt/intel/composer_xe_2013.1.117/licenses
    • 3. /opt/intel/licenses/USE_SERVER.lic
    • 4. /net/dubnfs01/fs9/prodsupport/mfirdaus/intel/licenses
    • 5. /opt/intel/composer_xe_2013.1.117/Licenses
    • 6. /Users/Shared/Library/Application Support/Intel/Licenses
    • 7. /opt/intel/composer_xe_2013.1.117/bin/intel64/*.lic
Please visit http://software.intel.com/sites/support/ if you require technical assistance.
icc: error #10052: could not checkout FLEXlm license
Anoop_M_Intel
For better support with Licensing issues, I am forwarding this thread to Startup Support forum.
Thanks and Regards
Anoop
Hubert_H_Intel
Hi Paul,
I've opened a support ticket for you.
Regards, Hubert.
Hubert_H_Intel
Hi Paul,
Is the problem solved?
Regards Hubert.
admin__license
issue resolved
