Software Archive
Read-only legacy content
17060 Discussions
Error: A license for FCompW is not available now (-15,10,10061).
Anand_Balu_N_
We are trying to run an older version of Fortran Composer 2011 due to it being used on a Windows Server 2008 machine.
The Composer will be used in combination with another software, Abaqus. All the software is downloaded and it seemed that everything is activated except for Intel which is giving the above error message when running the command.
The serial number activated successfully but we are unsure if the software requires the use of a software license manager to run.
Attached is the log file and can attach the license file if necessary. The license file does list the above module as well so it should have been included in the license I assume.
Kenneth_C_Intel
Hello it seems as if you haven't set up a license server.  We have a guide on setting that up here that should solve all your problems.  You will need to get the license owner to set it up.
https://software.intel.com/en-us/articles/intel-software-license-manager-getting-started-tutorial
Kenneth
Anand_Balu_N_
https://software.intel.com/en-us/articles/intel-software-license-manager...
Kenneth
Hey Kenneth,
I am not completely positive that this is a floating/network license. Nothing on the registration site/downloads page indicates this.Also, it does not allow us to download the license manager since the support expired (even though it says active 28 June 2016).
Could it be conflicting with a previous install?
Kenneth_C_Intel
Only the license owner can download the license manager.
Light_Intel
This issue has been resolved. If you have a similar question please start a new thread to ensure your issue is being addressed in a timely manner.
