Software Archive
Read-only legacy content
17060 Discussions
Error creating Live USB
NagaVenkat_K_Intel
I have created a Live USB using dd and after a while the USB died. I tried using a different pen drive and while booting it always displays MBR 1FA. I tried reformatting but still not able to succeed. Tried googling but no success. Is the problem with USB or am I doing something wrong?
Raghu Kona
Matthias_H_Intel
that means your flashdrive is automounted. Pls unmount first (sudo umount /dev/sdb1) and then dd over to /dev/sdb rather than /dev/sdb1.
In order to use all your 16 GB you will have to resize the partition after dd'ing which is described in another IoT threa (e.g. using gparted)
Brendan_L_Intel
Can you post the exact dd command you are using? Few common issues:
  1. no conv=fsync dd option and no `sync` done before unplugging USB stick for writing
  2. wrote to partition instead of directly to device node (/dev/sdX1 vs correct /dev/sdX)
  3. Image was not uncompressed (it's bz2 compressed so you need to `bunzip2` before writing
  4. USB stick is too small
  5. Image not fully downloaded
NagaVenkat_K_Intel
I am using this command
sudo dd if=devkit-live-img-final.binblob of=/dev/sdX bs=8M conv=fsync
Now I am getting a different error
dd: fsync failed for ‘/dev/sdb1’: Input/output error
955+0 records in
955+0 records out
8011120640 bytes (8.0 GB) copied, 692.881 s, 11.6 MB/s
Matthias_H_Intel
- check the filesize of the image (ls -la devkit-live-img-final.binblob) and compare with the size of your flashdrive (sudo fdisk -l /dev/sd<X>)
> is you your flashdrive sufficiently large at all?
- I would need to check - but the bunzipped bz2 image I downloaded was about 4GB as far as I remember. I am a bit puzzled your image is that large
- it looks like you dd'ed to /dev/sdb1 rather than to /dev/sdb (" ‘/dev/sdb1’: Input/output error") which would be wrong
NagaVenkat_K_Intel
The size of the devkit-live-img-final.binblob file is 8011120640 my flash drive size is 16 GB (14.9).
The downloaded unzipped file size is 4521773191
When i type the command df -h, USB is represented as
/dev/sdb1        15G  1.1M   15G   1% /media/raghu/C065-8342
so I used /deb/sdb1
Matthias_H_Intel
