Software Archive
Read-only legacy content
17060 Discussions
Error when creating new Cordova app
Aurélien_P_
I just installed Intel XDK 2893 on my computer. When I'm trying to create a Cordova app (with template or sample), I have an error :
Unexpected call to process.exit()
  • unknown
You can cancel plugin resolution and exit this project.
If I'm trying to create HTML5 only app, it's working fine.
Do you have any idea?
Rakshith_K_Intel
It could be a network connection proxy issue, that is failing to fetch plugins.
Can you try "upgrading" the HTML5 project that you created by clicking on the "Upgrade" button in the project settings page
Aurélien_P_
Thanks for your answer.
Upgrading worked but if I try to add a Cordova plugin, I obtain this error too :
I tried to disable Windows Firewall, issue was still here.
PaulF_IntelCorp
Check this FAQ to see if it might help, in the case where you have a proxy on Linux or Mac > https://software.intel.com/en-us/xdk/faqs/general#bad-proxy
Aurélien_P_
I'm using Windows 10 actually. It still doesn't work.
Marcelo_J_
solve this problem? I'm the same question
PaulF_IntelCorp
Marcelo -- did you upgrade to Windows 10 after the XDK was already installed on your system? If so, you need to reinstall the XDK (no need to uninstall, just go to http://xdk.intel.com and download the installer and install it a second time).
