Software Archive
Read-only legacy content
17061 Discussions
FFTW wrapper on MIC
Bruno_A_
Hi everyone,
I'm trying to run the MKL fftw wrapper on MIC, but it doesn't work. The code compiles and I can run the binary, but since I don't have the offload report I guess that code don't was really executed on MIC. The code is this:
#include <stdlib.h>
#include <stdio.h>
#include <fftw3.h>
// MAX 480
#define N1 1000
#define N2 1000
#define N3 1000
double getTimeElapsed(struct timeval end, struct timeval start) {
    return (end.tv_sec - start.tv_sec) + (end.tv_usec - start.tv_usec) / 1000000.00;
int compute3DFFT(fftw_complex *dest, fftw_complex *src, int dim1, int dim2, int dim3, int type, unsigned int flags ) {
	if( !dest || !src || dim1<1 || dim2<1 || dim3<1 ) return 0;
	//fftw_plan_with_nthreads(244);
	fftw_plan p = fftw_plan_dft_3d(dim1, dim2, dim3, src, dest, type, flags);
	#pragma offload target(mic:0) nocopy(p)
	fftw_execute(p);
	fftw_destroy_plan(p);
	return 1;
void print(fftw_complex *f, int n){
	int i;
	for(i=0; i<n; i++)
		printf("%d: (%g,%gi)\n", i, f[0], f[1]);
int main(void) {
	int i;
	fftw_complex *src, *dest;
	double time_elapsed;
	struct timeval start, end;
    	gettimeofday(&start, NULL);
	//fftw_init_threads();
	src = (fftw_complex*) fftw_malloc(sizeof(fftw_complex) * N1 * N2 * N3);
	dest = (fftw_complex*) fftw_malloc(sizeof(fftw_complex) * N1 * N2 * N3);
	for(i=0; i<N1*N2*N3; i++) {
		src[0] = i + 1.0;
		src[1] = i + 2.0;
	//print(src, N1*N2*N3);
	compute3DFFT(dest, src, N1, N2, N3, FFTW_FORWARD, FFTW_ESTIMATE);
	/*printf("\n");
	print(dest, N1*N2*N3);*/
	fftw_free(src); fftw_free(dest);
	gettimeofday(&end, NULL);
    time_elapsed = getTimeElapsed(end, start);
    printf("Time: %.3f seconds\n", time_elapsed);
	return 0;
I already changed nocopy(p) to in(p) and I get some warnings but the code executed in the same way.
I compiled with this command:
icc -o Xeon fftw_libmic.c -L$MKLROOT/lib/intel64 -lmkl_intel_lp64 -lmkl_core -lmkl_intel_thread -lpthread -lm -openmp -I$MKLROOT/include/fftw  -offload-attribute-target=mic -offload-option,mic,compiler,"  -L$MKLROOT/lib/mic -lmkl_intel_lp64 -lmkl_core -lmkl_intel_thread"
I also make export MKL_MIC_ENABLE=1 and export OFFLOAD_REPORT=2
Like I said, this code runs but only on CPU.
Can you help me ?
Best Regards
McCalpinJohn
I have not tried to do FFTs using offload, but aren't your arrays too big for the Xeon Phi?
If "fftw_complex" is based on "doubles", then your src and dest arrays are each 14.9 GiB.    Even with "float" variables, the two arrays would take 14.9 GiB together.
Jeongnim_K_Intel
Also, the fftw_plan needs to be created/destroyed in an offload.
fftw_execute(p);
Bruno_A_
Thank you both.
I tried the solution of Jeongnim but didn't work.
