Software Archive
Read-only legacy content
17061 Discussions
Facial recognition on remote server
joseph_c_2
I am a student working on a project which is using the realsense camera's facial recognition module as a login method for part of our website. Because it is running on a website we are unable to use the facial recognition module within the site itself. Our idea was to use javascript to capture the image information and then send it to our windows server which would then cast it to a PXCMFaceData and run the following (incomplete code) on it
	PXCMFaceData user = //data from javascript;
	PXCMFaceData.Face face = user.QueryFaceByIndex(0);
    if (face != null)
    recognitionData = face.QueryRecognition();
    if (recognitionData.IsRegistered())
		//do stuff
My first question is this, is what we are planning possible? is there a better way to go about it?
The other half of our implementation is getting our stored user information out of the database to use as a comparison. we are running a mysql server and plan to get the data from the database and cast it like so
		try
			SqlDataReader Reader = null;
			SqlCommand    Command = new SqlCommand("select * from table", //add correct SQL command COMMAND NEEDS to ignore any user who does not have facial recognition setup
                                             myConnection);
			Reader = Command.ExecuteReader();
			while(Reader.Read())
				user = (PXCMFaceData)Reader["faceRec"]);
				WWID.add(Reader["WWID"].ToString());
				if(face != null)
				recognitionData.RegisterUser();
This would create the local database used in the isRegistered() function, again is this possible? is there a better way to go about it?
