Software Archive
Read-only legacy content
17060 Discussions
Failed to install VideoEditor plugin
Ivan_M_1
I add Cordova Video Editor Plugin (https://www.npmjs.com/package/cordova-plugin-video-editor) but when build app I get error "Plugin "VideoEditor" failed to install.".
Can you help me with this?
John_H_Intel2
How are you trying to add the plugin? I just added it successfully using 3rd party git using this URL
https://github.com/jbavari/cordova-plugin-video-editor.git
Ivan_M_1
I added with "cordova-plugin-video-editor" in Cordova plugin registry. But with this git link it works fine.
Thank you
Ivan_M_1
Why I cant add this two plugins
https://www.npmjs.com/package/video-prefetcher (https://github.com/azu/video-prefetcher.git)
https://www.npmjs.com/package/get-video-duration (https://github.com/caffco/get-video-duration.git)
I get error message "Plugin vesrion not found"
PaulF_IntelCorp
Are you using the plugin manager on the Projects tab or are you using the intelxdk.config.additions.xml file? You should not be using the additions file to add plugins.
Ivan_M_1
I'm using plugin management under project tab (git repo under third-party plugins)
John_H_Intel2
Look at the error message that you are getting. It is complaining about a missing plugin.xml file.
Take a look at another plugin, https://github.com/phonegap/phonegap-plugin-barcodescanner, it DOES contain the plugin xml file. I am afraid this plugin will not be work with the XDK in its current form. I recommend finding a different plugin that does something similar to what you are trying to do.
