Software Archive
Read-only legacy content
17060 Discussions
Flash Edison over I2C
K_R_1
Assume I have two Edisons connected over I2C with each other.
With many of the newer PIC microcontrollers it's possible to flash the chip over I2C. For those wondering what I'm talking about, read for example AN1302 from Microchip. Basically part of the flash is reserved by the bootloader and the bootloader puts the firmware received over I2C in the rest of the memory.
1. Does the Edison bootloader support such operations?
2. If not, is it doable to modify the bootloader into allowing such operations?
Matthias_H_Intel
Don't have an answer just a note in case you haven't seen: you can check out the EDK sources for the bootloader
