Software Archive
Read-only legacy content
Fortran DLL not returning data
Gerrit_V_1
Problem:
I am porting a program with VB6 UI + Compac DLL to VB.NET 2013 + Intel Fortran (11.1) DLL
A small dummy program, in VS 2 projects (UI and DLL), works fine, i.e.:
- data input in UI
- data changed in DLL
- changed data displayed in UI
I'm using the following configuration:
- VS 2013
- Intel Frotran 11.1 for windows
- IMSL 7-1
When I replace the UI by the UI of the target program, but keep the interface to the DLL
and the DLL the same as in the dummy program:
- I can debug the DLL: so the interface is ok,
- but data changed in the DLL is not returned to the UI
- property pages are kept the same
Any suggestion what the cause might be, is highly appreaciated.
Georg_Z_Intel
is the question related to the debugger as you cannot display the data returned from a DLL in the watch window?
Or is this a general question to why passing data via DLLs does not work in your setup?
In any case it would help me and others if you could provide a stripped down example demonstrating the problem.
Thank you & best regards,
Georg Zitzlsberger
Gerrit_V_1
Hi Georg,
Thanks for responding. I will prepare a small demo. What I noticed in the meantime is that data are returned from the dll if the parameters are packed in an array, so basically there is a solution. But I don't understand why a single or integer parameter is not returning a value when changed in the dll.
Best Regard,
Gerrit Verboom
Gerrit_V_1
Hi Georg,
Please find attached a small VS solution of a VB UI and an Intel DLL.
The value of AB (single) is changed in the DLL, but not returned to the UI.
When changed to a one-element array, the value is return to the UI.
Looking forward to your remarks.
Gerrit
Georg_Z_Intel
Hi Gerrit,
this ain't a debugger question but a general VB to Fortran interfacing question.
Please use "ByVal ab As Single" and not "ByRef ab As Single".
Georg Zitzlsberger
Gerrit_V_1
Hi Georg,
Thank you, this indeed solved my problem. I must update my understanding of ByVal versus ByRef.
Best regards,
Gerrit Verboom
